Question about NetGear DG834G Router
Net gear router
Hi -  isp 192.168.0.1 will not load on my e-mac  - blue bar goes about 1/4 of the way along then nothing - did this with g - link router also - regards chris
    Scholar:
  • 77 Answers
You might want to try 192.168.1.1 I had a netgear as well and that was the gateway it assigned. I can't remember off hand but it will then prompt you for user name and password. I believe they both are admin.
Posted on Jun 28, 2008
Hi I configured wrt160n v2 linksys router well but when the power goes down and restart it again it stop working for more than 1 hr? any solution for it? Noor Muhammad ISP Engineer Multinet Kabul...
your ISP is a cable or DSL...??? if it is a cable then you should do a mac clone... if your ISP is dsl, then check with the direct connection from modem....Make sure the direct connection with modem is working good when the modem is restarted and connect the router...
Aug 10, 2010 | Linksys WRT160N Wireless Router
Internet connection fails through DLink router
Some ISPs (Internet Service Providers) require that you "register" the 'MAC' (not an Apple --> Media Acquisition Control) address of the network-adapter of your computer (or router) with the ISP,
before the ISP will allow your computer (or router) to be provisioned.
Your router has a different MAC-address than your computer.
So, your computer works with its "registered" MAC-address,
but your router cannot connect with its "unregistered" MAC-address.
Access the web-server inside the router, and click the 'Clone MAC-address' button, and restart the router.
Then, the router will send the MAC-address of your computer, rather than its own MAC-address, to your ISP.
Dec 31, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Limited or no connectivity
It is dhcp server issue.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to advanced and enable dhcp .
Then save settings and then restart .
Also you can set ip addrese manualy but make sure it is in range with router.
Let me know if you need more assistanse.
Thanks.
Sep 08, 2009 | NetGear WGR614 Wireless Router
Cannot get dlink 524 wireless router to work with HN9000
Hi! I will be more than glad to assist u in this concern..if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Jul 09, 2009 | Efficient Networks SpeedStream 5100 Modem
Internet wont work thru my Linksys BEFSR41 Cable/DSL Router W/4 Port Switch.....can i fix it or do i need a new one?
hi there, you need to configure the router first to connect over the internet.
checked if everything is properly connected, modem-router to the computer, checked the lights on the router and the modem as well if it is properly lit up.
if your ISP(Internet Provider) is cable then you need to clone the mac address of the computer, if you are running DSL, you need to input the username and password of your account from your ISP.
Accessing the router setup screen, open IE and type on the address bar 192.168.1.1 then nothing for username and password is admin.
on the setup screen you will see there Internet connection type, by default it is automatic configuration if you have cable connection as your Internet then leave it that way and look for mac address clone sub tab.
if you are running dsl for the Internet connection type you need to put PPPoE and input there your username and password from your ISP. then in everything you do you need to save the settings there.
tell me if it
Jun 26, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Jan 26, 2009 | Arris Touchstone 450a (CM450) Modem
Linksys Wireless-G 2.4Ghz Broadband Router Problem
This is a common problem with linkys wireless g routers, as you say that you modem works fine with usb..no problem with your isp, so go head and first upgrade the routers latest firmware..reset and reconfig your roter your issue will get fixed..try it out.
Feb 28, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
No internet connection
Some ISPs require you to register the MAC address of your network adapter before their DHCP server will issue you an IP address. The MAC address of the router is different than the MAC address of the NIC in your laptop. Call your ISP and they should be able to help you.
Jan 27, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
NetGear DG834G Router Logo
20 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
