After sync this month - the unit will calculate route then goes back to main menu. Reset no good problem remains. Even " follow map" it goes back to main menu. Any one know what to do apart from buy Tomtom?
Hi i have the same problem it works ok for the first few seconds of the instructions on how to reach your destination and then returns to the main screen on lock out if you do a soft reset it it will do the same ols with a hard reset
You can't post conmments that contain an email address.
I've wiped the card and copied the back files off the cd back onto it and put the update back on.
Seems to be working fine now but you will loose all your settings and favourates.
sat nav needs a valid gps signal to start calculating route, even if it found entered address. Address is searched on built-in map, not live gps position. That means, sat nav may have problem with gps signal. Try to reset device to its factory settings first. hope this helps
http://reviews.gpsfaq.com/downloads/eveshamnavcam7700software.pdf there is the software guide for you it has everything you need. If you have other issues you may need to replace the unit as you said it seems they are out of business. I would invest in a tom tom or something of the likes that is very reputable. Thanks, Lee
Not quite 100% sure what your description of the problem is saying.
If it isn't the auto shutoff but is when you tell it to follow a route or other function the problem is most likely a corrupted map or part of the map.
If it is brand new don't mess with it take it back. If it were out of warrenty you would have to reset or reload the map. It's not a major problem but for a brand new unit it just shouldn't happen. Garmin makes pretty good units so don't get discouraged by one being wonky.
There may be a setting somewhere to define your 'home' position. It will probably default to this location as standard until you find the setting and reset it to your own postcode/home address
Evesham is no longer in business but the following url is for a company that supports their products. They have ex-Evesham employees on staff.. http://www.tewktech.com/
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
