Carver stereo Tuner TX-10 after 5 or 10 minutes,it starts to make sparkish noise in the loudspeakers;I tried a different tuner in my system and everything came back to normal.So I don't have a reception problem with my cable connection. Thanks to help me. Ben b.menard@videotron.ca
informatica
  • 1114 Answers
SOURCE: hookups
You can download the manual from the link below: http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=TXSV414PROom.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 12, 2007
SOURCE: onkyo tx 902
I have a TX-902 owners manual.
It states:
Classified Memory Function. The memory can be divided for different users or programs of stations.
How to classify stations. With this model, six classes (Class A to F) are available and stations can be memorized in any class. A total of 30 stations can be memorized in any class. A total of 30 stations can be memorized.
1. Tune in the desired station.
2. Press the MEMORY button. The MEMORY indicator will flash for 8 seconds.
3. Press the desired Classified Memory button (one of buttons A to F). The station is memorized in the selected class with the memory number which is the smallest of the unoccupied numbers in the class.
By repeating the operations above, up to 30 stations can be memorized. Any more will produce "FULL" notice.
How to cancel memorized stations:
Retrieve the class number you want to cancel and then press the MUTE/MODE button while holding down the MEMORY button. Another station can be memorized with the memory number which has been cancelled.
Hope this helps.
Posted on Jan 08, 2008
SOURCE: Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Posted on Apr 10, 2008
  • 319 Answers
SOURCE: Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
Posted on May 07, 2008
  • 13 Answers
SOURCE: how powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Posted on Mar 04, 2009
Onkyo tx-88 will not power up
Internal problem with it, Take it in to be repaired,
Dec 02, 2012 | Onkyo Tx-88 Stereo Amplifier Tuner Tx 88
My carver tx-11 tuner will play for a while then the lights go out (exept for for power light) and there is no reception and then it will come back on after about 10 minutes and then go out again etc
You have a intermittent problem in the power supply board, the most likely cause is bad solder connections on the printed circuit board or a bordor line failure due to a part.
Jun 01, 2012 | Audio Players & Recorders
Westinghouse tv sk-32h240s after watching for 10 minutes srceen turns blue
That normally indicates that it has lost the signal from the tuner/cable box if you lose the audio as well. I'd try different inputs such as a Dvd player and see if the same thing happens. If it doesn't, then the problem could be a bad solder connection near or in the tuner or cable leading to the tuner.
Jan 29, 2011 | Westinghouse SK-32H240S Television
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
May 06, 2008 | Onkyo TX-SR605 Receiver
Phillips tv
Are you connected using R,G,B (component) cables? Check them to make sure they are in firmly - if so, then try a new set - that may very well fix the rolling issue. (Unless the rolling is caused by poor antenna reception).
Press "Sleep" on the original remote control for this TV if you still have it until the TV says "Sleep OFF".
If no strong TV signal is detected, this unit goes into sleep mode, which may explain Tuner B shutting off after 5 minutes.
Feb 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
267 people viewed this question
 Grubhead
Grubhead
