Question about GE Kitchen Ranges
F2 code appears and the range starts beeping stops cooking
    Genius:
  • 1,689 Answers
A generic work-around for most GE wall ranges / ovens... Press the CLEAR/OFF pad. Allow the
oven to cool for one hour. Put the oven back into operation. If
the function error code repeats, disconnect the power to the
oven and call for service.
here's the manual for a GE Wall Oven, it covers 4 models, i hope one of em is yours.
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JTP45WDWW
good luck.
Posted on Jun 24, 2008
    Master:
  • 638 Answers
Do Not try to perform the below if: Oven is under warranty,You are not handy with a soldering gun, or Are afraid to do this.
The below solution applies only to my in-wall oven with F2 and F3 codes randomly, but presumably will work with other GE models.
I had the same trouble with a GE in-wall oven. The problem was on the electrical board behind the keypad. A pin that was soldered to the board, that was the input for the oven temp sensor, had cracked solder. So I re-soldered the pin and hopefully it will continue working.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
    Sergeant:
  • 260 Answers
Unplug the range, wait 30 seconds to 2 minutes, and plug it back in. That will usually solve this problem. it is common for the ge kitchen ranges.
    Guru:
  • 1,894 Answers
Doing a hard reset wil make it disappear
try it and tell me
  • 2 more comments
  • dewan nafees ahmed Jun 24, 2008
    but it wil be better if u tell me the model number and make
    because many kinds of makes have the same error number with different problems
    so please tell the model number and make
    but generally F2 E0 code is attributed to a short keypad with the Electronic Range
    Control (ERC). The recommended solution is to replace the ERC.
    if you
    can give me the complete model number of your range (located along the
    opening around the oven door or lower drawer assembly).
    The model
    number includes a three-digit prefix. I would also need this to
    determine the manufacturer.
    ERCs can be expensive on some models. I hope this helps you.
    Well here's the details about those codes: in some other models
    F2 :-
    1. The oven temp has risen above 665F and the door is not locked or
    2. The temp has risen above 965F with the door locked
    1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
  • dewan nafees ahmed Jun 25, 2008
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
F2 and F3 Errors just started on my GE Electric Range
I had to clean the contacts in the control panel to fix my same problem.
Nov 10, 2009 | GE Kitchen Ranges
GE true temp oven f2
This happens every time I clean my oven. It overheats, shows the f2 light and BEEPS loudly. The only way to stop it is to turn the oven off at the breaker box, wait until it cools (usually 2-3 hours), flip the breaker back on and start the process all over again until the unit is clean. If it's not to dirty, sometimes it's easier to juat use Easy Off.
hope it helped
Jan 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
When we cook in the oven it says F2 every 10 mins.
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
Nov 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oct 17, 2008 | Whirlpool Kitchen Ranges
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
Jun 01, 2008 | Kitchen Ranges
Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
F1-2 Runaway Cook Lower Oven Check the sensor 1050-1100
ohms, wiring, control
F1-8 Keypad Shorted Replace Control
Here is the link for you to print off the service manual on your range
http://www.servicematters.com/maytag_library/docs/16010107.pdf
PLZ Rate my service
Feb 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
EO F2 code
F2 E0 code is attributed to a short keypad with the Electronic Range Control (ERC). The recommended solution is to replace the ERC. If you can post back with comments I can locate a part number for you if you can give me the complete model number of your range (located along the opening around the oven door or lower drawer assembly). The model number includes a three-digit prefix. I would also need this to determine the manufacturer. This way I can research to find a part number and price and see if this is a repair you would wish to pursue. ERCs can be expensive on some models. I hope this helps you.
Nov 11, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Kitchen Ranges Logo
137 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
