Question about GE Washing Machines
I just had a new GE washer delivered to my home today, June 24, 2008. All it will do is fill with water and than drain. The agitator cycle does not work and the spin cycle does not work. Model #WHDRR418G1WW, Serial # LR121396G. Do I need to call for another washer.
We had the same problem with our new GE washer.......the repairman just left. It's the circuit board on the motor that failed, causing the motor to stop working. GE will replace it under warranty.
Posted on Sep 09, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Why does my GE washer get stuck in Drain cycle??
for one G.E not a good choice mostly junk. the timer may indeed be bad if its sticking at 1 point and u can move it manually?
Feb 27, 2015 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Washer will not agitate but fills/drains/spins
Could be related to pressure switch which measures the amount of water in tub. Does it fill and then just sit there?
Nov 13, 2009 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
236 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
