Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi RLT30CES Hi, My Ryobi strimmer is hard to start but once started if turned off cannot be restarted again until engine is cold. I have only used it once! Any advice?
  • aky1967 Feb 04, 2009
    Hi
    I have had the same problem & spent a day stripping the unit down
    (dismantled & re-assembled the carb, seemed OK fuel reaching & flooding the plug) I unscrewed the spark plug from the body, but left it connected to the lead and found that there was intermittent spark when pulling the cord. and tested it with a continuity meter - no signal/measurement. bought a new spark plug, meter reading showed signal/measurement, now starts every time. It may be that Ryobi has been installing rather cheap nasty plugs. So test the plug first by watching the spark when pulling cord, test with a meter, if no continuity, buy new plug....this solved it for me
  • gesus May 11, 2009
    my ryobi is really hard to start, has never been good since i bought it? will try new plug see if this works
    Problem Solver:
  • 5 Answers
I also tried this.
  1. Clean the carb wire gauze air filter behind the roto-choke knob. (undo the nut/washers & long bolt)
  2. Deteremine if fuel is being fed to cylinder - Fully depress & prime the bulb about 7 times, turn to full choke. Pull start cord about 7 times. Remove spark plug see/smell fuel fumes/vapour present in cylinder
  3. Determine if compression is weak - remove plug, put finger over plug port, pull start cord. Should be evident of resistance/pressure build up when cord is pulled.
  4. Of course brand new plug!!! as above (I would try this first)
Hope this helps
please rate my comments - Thanks
Aky1967
Posted on Feb 05, 2009
How to replace fuel lines on ryobi rlt30ces line trimmer
Hope this is what your looking for.
Please rate me
Thanks,
Feb 15, 2013 | Ryobi Garden
Ryobi electric strimmer rbc 1000ex would not start
hi guys ,i have a ryobi electric rbc 1000ex and i've only used it about 5 times since new ,blue light comes on , but wount spin ? any ideas ?
May 12, 2012 | Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT 30 CES Strimmer - Won't run properl7
I'm not sure about the carb. adjustment being removed. The newer carbs. only have one dial for adjustment, not the two screws like the "old school kind".It probably needs the carb. cleaned. Disassemble the carb. and clean with carb. cleaner. Use a Den Tek Brush, (used for cleaning teeth), to clean the small portals. Make sure the small screen in carb. is free of debis. The smallest of particals can cause your problem. Reassemble and try starting. If it still acts up, buy a carb. kit for trimmer and replace the needle valve, appropriate gaskets, diaphragm, and small screen. This should solve the problem.
Jim
May 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi model RCT2800B grass strimmer will not start
close your carb adjustment screw a bunch of turns... yours may even be missing.
Apr 19, 2009 | Ryobi Garden
Please help me to stat this thing I have no manuel
When I first got my brand new RYOBI LIne Trimmer the *** thing just would not start. I was following the exact guidelines in the maual. First thing is, ensure you get right is fresh fuel correctly mixed accurately with 2-stroke oil. Some machines are more temperamental about the mix. 2. Set choke to COLD, press bulb 8 times (once you see fuel enteing the clear bubble reservoir) 3. Switch on power. It's amazing how often I've pulled the cord with that red button off. Dont think you cant do it to. 4. Pull the cord gently until you feel resistance. Let it gently recoil, then in one non-aggressive move, holding down the unit with your other hand, pull it out at constant speed. Do not yank! If (or rather when) it doesnt start, pull the accelerator trigger a couple of times only, and repeat procedure "4". Don't press bulb again too often or use the trigger too early or you will flood the engine. When I couldnt get my strimmer to start at all, I got this advice from an online engineer, it fired up *first pull*.
If it's not starting after a winter rest, did you store it empty of fuel because that is always wise. Discard old petrol mix and start with new. Hope that has helped.
Mar 04, 2009 | Ryobi 15" Electric Factory Reconditioned...
Starting problem with a Ryobi rlt30ces petrol strimmer
Hi
I have had the similar problem & spent a day stripping the unit down
Check also that little gauze air filter behind the roto choke is not blocked.
this solved it for me.
Please remember to give me a rating ...ta
Jan 25, 2009 | Ryobi 15" Electric Factory Reconditioned...
"warm" starting
Hi
You may have tried this already, Apologies if you have.
Jun 15, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES
I have one of these and I have to admit they are a bit of a bug*er to start. Following the instructions though on the sheet for trying to start it eventually should kick it off and then you should be away. I start mine by alternating between no choke and the half choke with about half a dozen pulls each. generally pull with the throttle held but try a few with it off every now and again. If you get to 10 mins without success, put it down, have a drink and a rest and go back in 30 mins and try again.
I wouldnt have thought a straight petrol mix would do it any harm though, if you had over mixed with oil then that could have been a differnt story.
May 25, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
683 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Roland W VanLue
Roland W VanLue
EugenesDIYDen
EugenesDIYDen
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
