Question about Kenwood Excelon KVT815DVD Car DVD Player
Park brake bypass via switch to ground
When i connect the park brake wire from the headunit to the switch do i then connect another wire from the switch to a ground or how does that work.
    Problem Solver:
  • 10 Answers
No just ground it out on this radio you dont need a sequence just ground it out with the black wire it will work fine
Posted on Oct 07, 2008
Hook up the pbrake to a switch than ground the switch you might have to turn the switch on than off than back on
Posted on Jul 21, 2008
Just connect the Park brake to a possitive it doesnt have to be the park brake!
Posted on Jun 26, 2008
Park break bypass
The wire from the headunit that says brake switch needs to be connected to a ground point on the vehicle to work
Mar 08, 2012 | Performance Teknique ICBM9803 In-Dash DVD...
How do i view video without hooking to brake cable?
If you choose to bypass the parking wire without using a module manufatured for that purpose; try connecting the parking brake to ground and test. If this doesn't work, you make have to use a two wire toggle switch. Connect one side of the toggle switch to ground and the other side to the stereo's parking brake wire. Switching it back and forth will supply the necessary ground for the stereo.
Mar 09, 2011 | Clarion Electronic Automatic Video Lockout...
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Parking brake safety bypass
If you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 26, 2009 | Jensen VM9510 Car DVD Player
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
How do i bypass the parking brake switch in order for my video to play
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
Jvc kd-nx5000 video bypass
ground the e-brake wire and your fixed
Mar 11, 2008 | JVC KD-NX5000 Car Video Player
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
Pioneer avh-p4900dvd
go to autozone or any parts store and buy a generic $5 relay.
1. connect "30" to the parking brake wire from the headunit
2. connect both "86" and "87" to ground
3. connect "85" to the remote turn-on wire from the headunit
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Kenwood Excelon KVT815DVD Car DVD Player Logo
288 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
