Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Gateway MFATXNINES2 300x
Opened the PC and find a soft black plastic device similar to a planter box.. 2.5 in X 3/8in X 3/8 in with a vert slot in one end. Why is it there and what is it for and where does it go. Tank You. Al
    Problem Solver:
I'm just answering because I got a response to my question and sort'a playing/paying it forward. I don't really know answer, maybe it's an electrical insulation barrier, maybe thermal, maybe a blank of some kind to keep a slot clean. If the vertical slot matches something then that's probably it's place, but, of cause, why?
Posted on Jul 02, 2008
How to remove exterior card cover so i can install a new card
Dear William,
Best practise: wear an anti-staic wrist-band! Leave machine plugged in to power but make sure that power is switched OFF at wall - (this will ensure that the machine is safely 'earthed'. . Open box cover - there are usually release button(s) to do this. Once computer box is open, connect anti-static wrist-band alligator clip to bare frame. The PCI-card covers are usually attached by one screw/nut: UNDO. Remove slot-cover. Insert new card into PCI-slot. Make sure it is home & replace locking screw. Remove anti-static clip. Close box. Power-up & let Windows find/install new device. I hope that this helps - 'b'ye - Bruce.
Jan 02, 2014 | Gateway DX Computers & Internet
Horizontal equally spaced black bars accross the screen when in playback mode similar to looking through partially opened venetian blinds.
You may need to clean the head on the device. You can purchase head cleaning tapes from most stores that sell the tapes, or goto a specialist camera shop.
Failing that, open the tape slot, tape the tape out, and with a soft cloth see if you can clean the small silver heads very gently.
Oct 20, 2010 | Panasonic NV-GS15 Mini DV Digital...
I have a Gateway DX4300 and want to use my LED TV with surround sound on a receiver as the monitor. No HDMI slot on computer so I have Y-connector in headphone jack on front of box and I plan to connect...
Open your sound contol monitor (the speaker icon in the system tray) and makes sure there are no checks in the boxes for audio output. Also make certain the audio out device is set to your sound device. eg "realtek HD Audio" or whatever your PC sound card is. Make certain the slider buttons are about half way up for the Audio output. If your sound card is installed ok. your sound should now work.
Mar 11, 2010 | Gateway DX4300-03 Desktop PC
How do you enable the pci express slot on gateway gt5674
OK, for this issue, we will start with a basic fix for this issue regarding a Windows XP Machine.
1.Navigate to and click the Start menu.
2.Find "My Computer" and right click on it. If this is not in your start menu, check the desktop, the icon should be there.
3.Select "Manage" and the Computer Management pane will open
4.Click on "Device Manager" to expand the installed devices on your machine.
5.Locate the PCI Express Slot in the list and right click on it. (You may need to expand "PCI Express Adapters" or similar to view the card.
6.Select "Enable" and the card should be good to go.
If you see a Red X through the listed controller, it needs to be installed with the proper drivers. This model Gateway drivers can be found at the following link.
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1015322R
Feb 25, 2010 | Gateway GT5674 Desktop PC
How do i connect power on the hard drive in gateway 510
open ur cabinet door there r white color power slots take any one insert behind hdd u will find similar thing on one end of hdd.
Jan 21, 2010 | Gateway 510 X PC Desktop
Can't find a manual for Gateway GT5428 motherboard
I believe that is a pci express slot (x1)
Here is the manual for your motherboard:
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Jun 28, 2009 | Gateway GT5428 PC Desktop
How do I replace the battery and where is it located?
Procedure:
Remove battery cover located under the hood on the passenger side in the back. Simply pry the plastic catch in the front, open it like a lid and jiggle it loose and set it aside.
Use the small flat screwdriver to pop up the center peg in the five peripheral fasteners holding down the plastic compartment cover that you just removed the battery cover from. Each of these has a small black plastic circular flat topped center peg inside a larger plastic circular disk which has 4 slots under which you can slide the screwdriver to pop up the center peg. When the peg pops up simply slide the screwdriver under the larger disk to remove the assembly and loosen that site of fixation. When all five fasteners are out you can remove the entire compartment cover.
The battery terminals are removed with the 10mm wrench
The black box in front of the battery can be lifted out of the way by pressing on the plastic catch in the front of the box to loosen it from the metal flange that it is attached to.
The metal battery holder is removed with the 10 mm wrench. The nut is removed and the long bolt is slid out of the holder and then unhooked from it's bottom anchor. Jiggle the metal bar over the top of the battery to unhook the back hook from its bottom anchor. It may be necessary to lift the plastic over the back of the battery gently and lift out the soft clear plastic washer fluid tube from its guides to get at the back hook.
Gently lift the battery out while holding the cables out of the way.
Tools required:
10mm wrench, small flat screwdriver
Procedure:
Tools required:
Procedure:
Tools required:
Procedure:
Apr 17, 2009 | 2004 Nissan 350Z
Plug sparked, screen black
replace the power jack...thats enough
Jan 03, 2009 | Gateway M305CRV Notebook
Sdio Wireless Lan Card Wlan 802.11b
The blank plastic is NOT to be used while other cards. I am assuming you are talking about the SD card slot on the side (black plastic filler) There should be no movement of the SD card when in place.
If you are talking about the CF card slot on the top of the Axim, again the blank plastic is a dust cover when no card is in place and is not used with cards inserted. There is a bit of open area on one side of the card. Carefull with the pins at the bottom and be sure to insert correctly. Again there should be no movement of the card once inserted fully.
Don't know what you are quoting from the manual. I still have mine and the only thing I see similar to your quote is to "align the tab on the back of the CF card with the notch in the CF slot.." This is to make sure you have the front and back correct and for removal of the card (by grasping the ridge/tab)
Jul 29, 2008 | Dell Axim X5 Pocket PC
Screen went grey the black
theres either a brown or white slot they are long in shape and thin so if you have a brown slot that would be a "agp" if its a white slot that would be a "pci" so open the case and look inside on  the motherboard
Oct 13, 2007 | Gateway 505GR PC Desktop
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
