Question about Fujitsu fi-5120C
How to remove Assembly pad message after replacement
Received a Fujitsu fi-5120 C message that it is time to replace the consumable supplies pads in the paper feeder. The pads have been replaced but how do you remove the message that keeps popping up
    Problem Solver:
  • 8 Answers
You can reset this message in the scanner controll panel.
Please call windows <start>
<system control>
<scanner and cameras>
open <scanner and cameras>
inside you will find your fujitsu scanner fi-5120C
now call <attributes>
-- in WIN2000 there is a button, in XP use the right mouse button--
in <device settings> you see the ADF counter, an the consumable counters for pad and pick roller.
Reset the changed parts, confirm the EEPROM writing
and the message will be cleared.
Posted on Jul 15, 2008
Scanner continues to search for a page after all pages have been scanned.
Usually the "paper empty" sensor flag gets stuck and does not return or "fall" to the empty position when the paper ends.
The flag is right next to the pad assembly.
Use a compressed air can to remove any dust-debris from the flag housing.
Because this flag uses gravity to return to empty position it might be usefull to use a spring to force it. Let me know if you need further assistance.
Feb 13, 2015 | Fujitsu fi-5120C
We are a medical office that is currently using the fujitsu fi-6110. When scanning documents the feeder is pulling through 2-3 pages at a time and we are not getting all of the documents scanned due to...
Hello Jenny,
Please clean the followings using a cloth/ cleaning paper moistened with iso-propyl alcohol:(Pls refer to page-95 of your scanner getting started guide)
1.Pad Assy 2. Ultrasonic sensor 3. Idler roller 4. Pick roller 5. feed roller 6. Eject roller and 7. Glass surface
If the above doesn't help, then check the Pad Assy & Pick Roller count. If the counts exceeds the suggested replacement cycles, then you you may have to replace the same. Pls refer to page-99 of the getting started guide supplied with your scanner.
Hope the above information is helpful.
Thanks & regards,
Sep 12, 2013 | Fujitsu fi Office Equipment & Supplies
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel.
Sep 30, 2010 | Fujitsu fi-5120C
I have a Fujitsu 4220c2 scanner and when scanning multiple documents it'll take one half half/quarter way through and get stuck. The pick roller and pad assembly have been replaced. What could be causing...
Please go throgh my answers posted posted 6 days ago. Hope the Hope the information provided in that post will be helpful.
Please revert if you have any doubt.
Aug 10, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
The feeder takes several sheets at a time. How do
When ever you face such type of issue, the Scanner will display U-2 error with the Red led blinking and the TWAIN display will be "The multi feed is detected.(Code DS32006)".
To resolve the issue, please follow the steps provided below:
#Check if the documents satisfy paper specification? Please refer to the Operator’s Guide for paper specification, paying
attention to the following points:
• Is there any print within 10mm x 10 mm square in the center of documents on the top?
• Is multi feed error detected by paper length when scanning documents with different length?
• Is there perforation in the center of documents?
#Check ADF and clean pick roller, Pad ASY and around DF sensor with care.
#Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the permitted values, replace Pick roller or Pad ASY. If the error still occurs, confirm that the cable is correctly connected then replace the sensor.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
May 06, 2010 | Fujitsu fi-5120C
When I switch on the scanner it dispalys a E2 Message
Open the front door and look for a small switch actuator that has been knocked out of position
Aug 26, 2009 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu FI-4220C only scans one page at a time.
The problem is not just to roll over, be changed and separation pad. These two components change very easily and boxes that are delivered and indications for replacement.
These are the codes for parts:
Pad Assembly - Part Number: PA03289-0111
Pick Roller - Part Number: PA03289-0001
After replacement counters to be reset for each Pieces. Open the scanner properties.
Usually have to display a maintenance message on the computer display, such as: separation pad should be replaced.
If there is to scan any messages like that, you have to clean the sensors around the separation pad. They are round and are getting a little inside. Click on the blue button at the top of the ADF and open the lid.
I hope you was helpful.
Aug 10, 2009 | Fujitsu fi-4220C Flatbed Scanner
Paper jam
It seems youre facing an issue with the scanner consumables - pad and pick roller. It is a goos idea to replace both of them at the same time. Also check the feed and exit rollers (the two rollers on the upper part of the scanner) as the get sticky causing problems like the one you describe.
Sep 27, 2017 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
May 29, 2008 | Fujitsu fi-5120C
Fi-4990c problems- front optical sensor
fi-41990 scanner cleans after scanning 100,000 sheet for paper roller the pad cleans after scanning 100,000 sheets feeding path cleans after 200,000 sheets
Aug 09, 2007 | Fujitsu fi-4990C Path-Through Scanner
Fujitsu fi-5120C Logo
3,694 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
