Question about Honeywell Heating & Cooling
We had a Honeywell 5220D installed by a HVAC company in April. Now my AC runs fine during the day and at night about 10PM the inside fan continues to run the thermostat is not yet at temp and the outside compressor fan does not run until the sun comes up. I have checked to see if it was in economy mode and it is not. The temp inside will warmup 6-8 degrees buy morning and the unit will come back on some time after we have gone to work. any ideas? Thanks Gary garyhenry@kw.com
    Sergeant:
  • 359 Answers
Make sure the temper differ in cool mode are set 40-90 this is also a programable feature of this t-stat , by the way it also has offsets in the heat mode you might want to check this as well and make sure they are set check all wire connections for tightness and placement, also check to see if the t-stat is set to change from heat to cool auto mode or manual set to manual
Posted on Oct 26, 2008
The coils are freezing overnight
Dirty filter,undercharged, evap. coil plugged.These are some possibilities, also tstat may be set to low adjust to reasonable temp
Apr 01, 2015 | Heating & Cooling
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
We are in a 5th wheel RV. We have a factory installed Carrier a/c in the kitchen. Lately, it shuts off during the night and we have to reset it in the am in order for it to work. It works fine during...
If the outdoor temps are cooler than inside, AC's are not made for this and will not work well if that is the situation, it floods liquid to the compressor which will overload. will it reset within 20 mins of going off? if so the board/stat are suspect, if not the compressors the villain and its tired and cant handle the other than design condition of 95 F outdoor/80F indoor.
Sep 09, 2011 | Dometic Rooftop RV Air Conditioner
I had a Honeywell Thermostat RTH8500 installed by a pro to run Heat / Cool electric heating WITH central air conditioning. Problem : When running on cool Fan on auto ,it work OK but sometimes when the...
Is this a new hvac system? A new furnace can work differently than your old one. Does it shut off after a minute or two or continue to run? If it continues to run then call that professional back and let him fix it. If it shuts down after a minute or two then it is a feature of the new thermostat to squeeze all of the cool it can from the a/c coil and ductwork.Some of them have settings that you can adjust for blower delay on and off, read the manual that came with the t-stat and see if it does.
Jun 16, 2011 | Honeywell Heating & Cooling
WE ARE CURRENTLY IN NORTHERN TERRITORY VERY HOT AND HUMID. RUNNING AC THRU THE NIGHT IT STOPS BLOWING COLD AIR AND FAN SEEMS TO BE NOISY. HAS IT ICED UP DUE TO THE HUMIDITY. UNIT BEING RUN THRU THE DAY NO...
If your coil is freezing at night, it sounds like your getting cold enough at night to have your saturation temperature drop below the design of what the AC is able to do. If it runs all day without an issue and freezes up at night, you need to add what is called an outdoor fan cycling switch. This will turn the condenser fan off when the saturation temperature drops so it will not freeze your coil at night. You need to have an HVAC technician install this. It is not a DIY projuect since it has adjustments that need to be right. Plus, it it's a heat pump, it needs to drop the switch off in the winter.
Sep 28, 2010 | Heating & Cooling
I purchase a 1997 Salem camper trailer and just replaced the Duo therm 13,000 Unit BTU. Everything was good until it was time to connect the wires from the thermostat unit to the analog thermostat on the...
Pay attention to wires from control box itself at the ceiling assy. Sometimes they will use a different color from control box, to thermostat. For example: Green coming out of control box, is attached to a blue running to thermostat, so you would attach that blue, to "G" (fan) on thermostat. Match thermostat colors to what is at the control box originally, not what color they used to run it to thermostat from there. Most try to match them, but others don't. What model Ac unit, and what model of thermostat do you have?
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
Goodman Heat Pump freezing up
In your climate usually the defrost timer would be on 90. However if you are in an upper elevation and it gets colder then set it at 60. what model unit do you have? Did they change both indoor and outdoor units? I would have to know the model # to tell if the fan should run in defrost. In most cases I would say no.
Jan 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
237 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
