Question about Sharp Audio Players & Recorders
When I slot a mini-disk into my Sharp mini-disk player, it always comes up with a Toc error and switch itself off.
  • jhydeonline Jun 24, 2008
    I've tried a number of mini-disk and I still get the same error. Does that mean the player has come to the end of its life?
    Novelist:
    Champion:
  • 210 Answers
If its doing it on all disc's it sound like the laser is dying or carriage mechanism is dying, if its either of these it will not be worth repairing it unless you can pick another MD player cheap and strip the parts out of it and replace them in yours, but thats if you feel comfortable doing the work yourself, if not its a replacement MD player i'm afraid.
Sorry.
Cheers
Posted on Jun 24, 2008
  • 3,037 Answers
There are many people that have experienced this error, Sharp will do nothing for you and most likely you will end up throwing it away. I believe that the problem lies in your laser. You could try cleaning it with rubbing alcohol and a q-tip otherwise you can also try redownloading or resetting the firmware on the player. Sharp should have the firmware on their website otherwise other websites will provide it free too. Let me know if you have any other questions with it.
  • 4,234 Answers
This type of player is not the type to be opened up by anyone without experience. There is also a magnetic head inside that is used to determine the correct track in cluding the TOC. This can be a simple repair or complex. If the optics are bad, the unit is not worth repair. Sometimes the optics just need an alignment. This requires test gear however and can not be done without it.
Keep us posted.
Dan
  • ABRsvcs Jun 24, 2008
    Forgot to add:
    1) This problem is not caused by a bad battery. There is no battery inside that could cause this.
    2) While it is possible that the lens itself is dirty, in my experience this is not the case either.
    Dan
  • 38 Answers
Toc errors accor when recording from normal CD's to MD it refers to a problem to the disc click here for errors page
    Master:
  • 788 Answers
Read here: http://members.aol.com/BorusSylt/minidisc.html
and here: http://www.minidisc.org/repair_q2.html
Seams as though there are many reasons for this kind of error. The player is not getting a proper TOC from the disc and is failing. Could be motor failue, could be read head failue, could be electronics failure. Unfortunately this late in MiniDisc's life there is not much that is worth doing. You should be able to find some fairly inexpensive MiniDisc players on eBay.
    Sergeant:
  • 243 Answers
The unit has come to the end of its life as you put it and needs to be serviced. If you give me the exact make and model i will be able to tell you more info about your problem.
    Master:
  • 848 Answers
First check the battery .......replace new battery and see whether it works properly ............ if the problem is not fixed .......then just try to replace the slot ( mini disk holder) in the player for inserting minidisk ........i think your player doesnot seem to be gone ......it will get fixed soon
  • 44 Answers
I think service is needed...or go for the manial.. this may work.
    Genius:
  • 1,142 Answers
It it the read lens which has gone bad or it needs a cleaning,,, might be the dust accumalation which has covered the lens layer from reading the disk,,, try to open the unit and with a soft damp cloth try to clean the lene gently this will resolve your problem
Regards
    Sergeant:
    Champion:
  • 359 Answers
Yes unfortunately its time to scrap it
    Genius:
  • 3,422 Answers
I am sorry to say this but you will have to get this repaired and this the only solution to fix the problem.The TOC error shows up when the unit can't read the Table Of Contents of the disc (and simply shuts down after trying).You can try cleaning the lens.
Please don't forget to or accept the solution.
Goodluck..
    Genius:
  • 2,028 Answers
If you've tried several then the optical eye is shot. The error usually will only be for one disc, maybe two. I don't know what the repair will cost, may be a good excuse for an upgrade.
    Sergeant:
  • 260 Answers
Usually the problem your describing is the result of a bad battery or a battery that needs to be reset. You can reset a battery by running it all the way down and then charging it up again all the way and then repeating that again. It does not matter if you plug the device in. If the battery is bad it will still likely cause this problem.
  • 1 more comment
  • Ken Jones
    Ken Jones Jun 24, 2008
    If the device is switching itself off and you cannot replace the batteries then the answer to your question is yet, the device is nearing the end of its usefullness.
    Ken
  • Ken Jones
    are you asking about this model # MD-MT821
  • Ken Jones
    http://www.minidisc.org/manuals/sharp/sh...
    here is the manual for the mdmt821. page 39 addresses the TOC error. Page 40 address battery replacement. Please let me know if I can answer any specific questions.
    Ken
    Master:
  • 638 Answers
Servicing immediately required.if it does not solve only option is to replace it.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • Sharp Master
  • 13,433 Answers
Try another mini-disc, if the disc is working fine, then there is a problem in the reader. You might have to replace it.
  • Ekse Jun 24, 2008
    you could attempt to clean it, other than that take it in for repair or buy a new one.
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
SHARP MD 722 MINI DISC,REED, TOC ERROR 3 ,and close, how to fix it -thank you
.Download your owner's manual here - http://www.minidisc.org/part_Sharp_MD-MS721+MS722.html
Nov 05, 2012 | Audio Players & Recorders
MDS JE520 Disc stuck in unit Toc light on. Previous to this state C13 error flashing.
the C13 is a mechanism error. The TOC means Table of Contents which is the part of the disk that determines the beginning of each track. These units are somewhat delicate and not really DIY repair candidates. Parts are still available for these. Look for either an authorized Sony service center or at least a shop that has worked on these in the past for repair assistance. The loading mechanism may need to be repaired or replaced.
Dan
Feb 03, 2011 | Sony MDS-JE520 Mini Disc Player
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Nov 06, 2010 | Sharp MD-MS702 Personal MiniDisc Player
Ive just got a mini disk player and its comeing up toc error,can you help me please
Probably not. There are various reasons that TOC errors occur, some are fixable and others not, but Sharp MD units were really known to suffer from them for multiple reasons all at once. TOC means Table Of Contents; it's an index file on the disc which tells the host machine where everything on the disc is located and the TOC is modified whenever you edit a disc. Sometimes the file gets corrupted, but often the machine itself simply becomes unable to read the disc and as the TOC is the first thing it tries to read then you get a TOC error.
If you're lucky the TOC error is limited to a single minidisc; if this is the case then it's just one faulty disc and although there are ways to perform TOC cloning they usually involve hacking the host machine in various ways which may cause permanent damage. Unless the disc is important, just chuck it away and use a new one. If the fault is with the player then again, just chuck it into the nearest electronic waste recycling bin. Spares are not available, and as it's a Sharp, diagnosis will be difficult and the fault likely to return.
Many MD players are practically worthless these days so they're often available on FreeCycle and Freegle groups: Sony are the preferred choice by far, and are also the most commonly offered brand, but take whatever is on offer without complaint and worry about problems later; after all, they are free.
Mar 03, 2010 | Sharp Audio Players & Recorders
When i inserted my mini disc it said TOC Reading then said Toc Error and C14. What is the problem?
Sounds like you lost power when you were finishing recording a disc. On a home unit it got unplugged before you had the TOC written, or on a battery unit the battery died when it was writing the TOC (table of contents) for the disk.
Jan 01, 2010 | Audio Players & Recorders
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
MD MT80 Mini Disk Player/Recorder
I have a DVD player which does not turn on only the sound (click-click) comes out.but when i took ont the cable connection to the main board the sound stopped.
Jan 21, 2008 | Audio Players & Recorders
Toc error problem
HEY,
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Sep 20, 2007 | Sharp MD-MT20 Personal MiniDisc Player
95 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
