(1) After making a copy (as always) the numers window displays: "2", "7", "E" one after the other.
(2) Dialog box pops up displaying" "Ink absorber full"
(3) will not print!!!
Can u tell ur problem clearly....
Did u try for a reset??
for any kind of error do a reset first
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
This simple power off procedure worked on my IP1500!
Cleaning
the absorber was also easy. Power up with the cover open until the head
moves to the left side then disconnect the power cord so the head is
now positioned away from the pads.
The two pads can be lifted up
easily with a pair of sharp tweezers then rinsed in running water. They
will become white again and can be blotted with paper napkins then air
dried in a warm location (I used an industrial oven set to 40°C). The
wells in the rubber holder can be cleaned with cotton swabs before
returning the two pads (left side first, then press down the right
side).
A waste ink absorber is a pad that soaks up waste ink.
An absorber can only hold a certain amount of ink, too much ink leads to spillage.
Canon does not publish a reset as then end users would be mad when the waste ink overflowed and stained their furniture.
credits:fixyourownprinter.com
Taking the sides off you can unsnap plastic clips to remove the top
half of the printer cover. Following the silicone tubes... they run
into a white plastic pump that sucks the ink that falls onto the pickup
screens and dumps it onto numerous felt absorber strips under the pump
mechanism.
To clean or change the absorber felts you must first
remove the Pump mechanism which is held on by 2 screws so that you have
access to the felt absorber pieces.
If cleaning the pads... run
clean water over each piece of felt until the water runs clear. Then
place them on an absorbant surface (paper towels.. newspaper etc.) and
let them fully dry.
Then reassemble the whole thing in the reverse order.
You have a few choices before you start....
1) do the above proceedure and spend some time.
2) take the printer to cannon and spend some money.
3) buy a new printer and spend some money.
dont forget to accept MY solution if u go by it.
feel free for asking any doubts u have.
thank u for ur cooperation.
good luck for getting fixed soon
