Question about Linksys RVS4000 Router
VPN passthrough I was told at best buy I can interconnect linksys products with netgear products. I am trying to connect a VPN tunnel from the linksys to the netgear. The netgear products were already in place and worked properly. But I had to change out one of the netgears for linksys.
  • 3 Answers
What are the settings that you have for your netgear router? Its going to tunnel, right? Try this solutions and see it will work.
1. Access the set-up page of the router, from a browser, type 192.168.1.1
2. Go to VPN tab and select IP SEC VPN
3. Local Security Group, set it to subnet and input the Network Address of the router (LAN IP - 192.168.1.0)
4. Remote Security Group, set it to subnet and input the Network Address of the netgear router (LAN IP, for example - 192.168.2.0)
5. Remote Secure Group, set it to IP only, WAN IP address of the netgear router
6. For Key Managemnt, just make sure that all settings are identical with the netgear router
7. Last go to Advanced Settings and make sure that group settings are identical to the netgear router
Hope it works for you
Posted on Oct 08, 2008
How can i configure my vpn router rv042
need VPN client or VPN router on the other side as well to creat VPN tunnel
Jun 19, 2014 | Linksys RV042 VPN Router
I have a WRT54G Linksys Wireless Router and can not VPN or Remote to a server from behind it
It is a passthrough router. you can not create a tunnel using this router. Now if you are using any VPN software to connect to the network then you can try to open the ports on the router.
Reduce the MTU to 1365.
open the ports - 500 , 443-447, 1723, 10000-2000
Try this.
If your router is old then upgrade the firmware of the router.
Apr 23, 2010 | Linksys Wireless-G WRT54G Router
I am unable to connect Linksys BEFSX41 and Sonicwall 3060
Check out this post:
http://www.dslreports.com/forum/remark,5336853
This person seemed to have no problems with it and includes configurations.
I would also make sure both are the same version or same firmware, I have had trouble in the past with netgears having different firmware not allowing a vpn to be configured.
Jun 26, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
Private network > VPN > network firewll > priv net
Add a static route on the Sonicwall 2040 : 192.168.1.0/24 with the RV082 as gateway (the ip of the network shared between the RV082 and the Sonicwall)
Another solution is to enable NAT on RV082 for 192.168.1.0/24 network. Routing is preferable.
Feb 14, 2009 | Linksys RV082 10/100 8-Port VPN Router...
Vpn
this is not so much a soloution but an idea!
from memory the netopia devices allow you to configure a dmz device by IP or MAC address.
I have had to do something similar but with a buffalo unit instead of your linksys. I ended up having to place the buffalo unitin into a dmz created on the netopia unit. before VPN tunnles were formed correctly.
Nov 01, 2008 | Netopia 2247NWG-VGx Wireless Router...
Configure VPN
That 3Com really doesn't have a wahy of setting up a VPN.
As per the 3Com site it:
Support of VPN termination/initiation and passthrough allows secure connection to central office and/or secure access from remote workers.
So it will allow 3rd party VPN setups to pass through, but it doesn't have the ability to create one.
You might want to look into something like a Netgear Firewall
http://www.netgear.com/Products/VPNandSSL/WiredVPNFirewallRouters/FVS114.aspx
Aug 09, 2008 | 3Com OfficeConnect Cable/DSL Router 4 x...
Can't connect to AT&T VPN
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Mar 04, 2008 | Trendware 54Mbps 802.11g Wireless AP
Gateway to gateway tunneling vpn
can you provide more information:
- WAN IP addresses of both routers
- LAN IP of both routers.
- name of ISP for both
i can provide a solution if i will know these info
Nov 16, 2007 | Linksys RV042 VPN Router
Linksys Routers and Microsoft PPTP
Microsoft uses IP Protocol 47 [GRE] for this secure tunnel. Provided that the PPTP Pass Through is set to Enable on the Router's Filters page and port 1723 is forwarded to the VPN Server, the Router will allow authentication and remote access into your network. The router will also allow you access remote PPtP networks from behind the router providing the PPtP Passthrough is enabled on the router.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys RVS4000 Router Logo
312 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
