Question about LG DLE5932W Electric Dryer
DLE5932W - Not shutting off when clothes are dry - keeps running
Thanks in advance. I have always used the sensor dry options (rather than timed) so that the dryer shuts off by itself when the clothes are dry. Recently, it no longer shuts off - it would run for days if we didn't manually stop it. We've checked to ensure there is no link blockage between the dryer and the external outlet, and there isn't. Any ideas/suggestions? Thanks much
  • squirt240 Jul 09, 2008
    My dryer also does not stop when I use moisture sensing controls.  The timer works fine, just not the auto dry.  Replacing the computer control panel seems a bit drastic - wouldn't it just be a problem with the sensor?  I tried washing the sensor itself with a little dish soap in case fabric softener had built up on it.  I read somewhere that it was common for the sensor to stop working if you use fabric softeners.  Could the sensors just need replacing?
    Thanks for thinking about this a little more.
    lorigregory24@yahoo.com
  • 489 Answers
You have a computer control board problem and needs to be replaced.  The internal program has a problem and won't time down properly.
Posted on Jun 26, 2008
I have a LG dryer model DLE5932W that will not shut off on its own
The cycle timer may be hanging up at the 1-minute point.
Aug 31, 2016 | LG Dryers
Dryer will not stop when clothes are dry in auto-sense mode
Try "timed" cycles. If it shuts off on timed it's not the timer. It's more likely it's not cycling on the thermostat due to an airflow problem like the vent. To rule that out (or in) run ONE load through it with the vent disconnected. If it shuts off you'll know where to look
May 03, 2014 | Admiral AED4475TQ
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
The check filter light is on. The clothes are not
The check filter light, is default message LG was put in place. No problem there. As for the clothes, I'd need some more infomation, what settings are you using on your dryer? I'll need to know if your using sensor dry, or manual dry.
Jan 30, 2010 | LG DLE5932W Electric Dryer
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Auto feature
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Jan 26, 2008 | Whirlpool GEW9250 Electric Dryer
On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
I'm sorry to hear of your problem with your LG dryer. I have one as well and it works very well. I found my owners manual. It has a web site WWW.LGSERVICE.com. They also have a toll free number 1-877-714-7486. Perhaps either of these will help you find an answer. Good Luck
Dec 03, 2006 | LG DLE5932W Electric Dryer
LG DLE5932W Electric Dryer Logo
324 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
