Question about HP OfficeJet G85 All-In-One InkJet Printer
OfficeJet G85 new computer has no phone jack port to use computer fax
I have a Mac Pro and it only supports ethernet. I can use the printer for everything except faxing to my computer because the only out port is a traditional phone jack. Is there any way to work around this problem?
  • Carol Chihara
    Carol Chihara Aug 16, 2008
    I have the same problem with my new intel iMAC.  Don't like seeing that cord hanging free. Help?
Just us a phone wire and it fits in an Ethernet port
Posted on Dec 01, 2008
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
I have a dial tone coming out of the jack on the wall that is only for this fax machine but the fax machine is saying phone off hook.
,Line should be connected to directly to printer line in port, parelall phone should be connected to extention port,don't split the line for printer & phone. Telephone line voltage should be 48V with/without line connected to the printer, if any voltage differce replace LIU card..
Sep 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Cant send fax dials squeals and cuts out and busy signal?
Hi There!
Please check if the phone line where the fax machine is connected is working. You may try to disconnect the fax machine from the walljack and connect known-working telephone on that jack and try to dial/call anyone. Because sometimes this issue can be caused by the problem on the phoneline.
Hope this helps. Please rate if it works. Thanks
Mar 31, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Vista driver for hp g85
Uninstall current driver (if any) before installing the new software from HP support: (choose your OS)
HP OfficeJet G85 Downloads
Jan 08, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Etherner will not connect
The ethernet connection on the printer is for a router.
You don't connect directly to the computer with the ethernet connection.
If you want to connect directly use the usb port on the printer.
Sep 17, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
My hp officejet G85 won't successfully send multipages faxes Can you help me with this problem?
Not sending multipage faxes I will assume the pages are not feeding correctly. If this is the case replacing the entire ADF would be the easy fix.
Not available new from HP as far as I can tel but available if you search G85 ADF.
If machine is terminating the connection try reseating th LIU this is the board the phone line plugs into. part C6735-60009
Hope this helps
Mar 06, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
G85 not being recognized by computer
Do you have the Software/Install CD that came with it? Does the CD cover Windows XP? The original G85 software was only for Windows 98. Later, they finally developed the software to cover Windows XP.
Apr 13, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Fax rings but will not pick up or give fax tone
hmmm..that's a fax settings issue on the front panel...you may new drivers for that hp.
get them here
Feb 28, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
208 people viewed this question
Seeker5211
Seeker5211
