Question about Kenmore 57029 Side by Side Refrigerator
Floaters in filtered ice water
"I am getting white floaters in my ice water. I have replaced the filter, let a lot of water flow through but the problem remains. What are they? Where do they come from? Are they dangerous? How do I get rid of them?"
Another user posted a probable cause -- hard water mineral buildup -- but noone has offered a solution
  • 5 more comments
  • kwoerpel Jul 25, 2008
    Removed filter in line and filter in refgerator and still have the same problem. Fkushed for hours, no improvement.
    What is it? How do I cure?
    KW
  • Anonymous Aug 12, 2008
    Same problem! Looking for a solution ...
  • Anonymous Nov 25, 2008
    I have a maytag french door with ice maker in bottom freezer and suddenly, within the last four months have started having white, filmy floaters when the ice melts. Have changed filter twice and ran water through lines several times, five - ten minutes at a time. Chilled water from door is clear as is water from kitchen tap. It is just my filtered-water ice.
  • Anonymous Dec 22, 2008
    we're getting the same thing, white floaters, but it's from the ice.
  • tick497 Feb 06, 2009
    Same problem, it is from the ice and I just can't bring myself to drink it! Please help, fridge is only one year old!
  • cilleymomma Mar 24, 2009
    Same problem...can anyone help???
  • russ_ksu1 Apr 09, 2009
    Hey guys, same problem here. My fridge is a brand new GE profile so it isn't something unique to your Kenmore. I froze the chilled water from the door and thawed it. Same floaters. I've boiled it in the microwave to attempt melting the little floaters. No luck, once they form they are sticking around. I'm not sure where to go from here. Right now I have tap water in the freezer. Going to try a freeze and thaw cycle on it and see if I can isolate my fridge as the problem. I'm starting to think that it is whatever my city uses to treat its water. Guess I need to get rid of my clear glasses or move!
  • 11 Answers
It is caused from calcium carbonate and magnesium among other minerals and is in hard water. When you pour the water out of the tap, no floaties, but when you freeze water, the freezing process forces the minerals into the center of the ice where it forms floaties. It is harmless, just unsightly. You can core the center of ice cubes to remove most floaties but that is impractical, so the other alternative is to get a water softener. Water softeners remove most if not all floaties.
Posted on Apr 08, 2010
Freeze hot water. my mom has been doing it for years to stop the floaties, and it has always worked.
Posted on May 11, 2009
What is the meaning of D02 in Samsung watching machine
D02 Error may have following Causes:
1-drain hose kinked or plugged
2- drain pump failure
3- accumulation of debris in filters and causing the floater positioner got stuck
if there is the flow of water through the drain hose it may that the floater inside the bath got stuck, if this is the case, remove the filters, unfasten the bolts and remove the inside cap until you can see the floater.
clean debris from inside surface of the washing machine and also clean the floater.
Posted on Aug 21, 2015
Dec 19, 2015 | Samsung Washing Machines
Timer ice maker kenmore side
If the timer piece you are referring to is behind the square white cover, and it's moving slightly back and forth, you should visually check the ice making area it's self to see if the ejector fingers are jammed with ice, or against the ice stripper. Ice Maker jams can be caused by reduced water pressure to the unit mainly from the water filter, your water filter in the toe kick should be replaced at an interval of 6 months to a year, regardless of filter status light. When water pressure is low, not enough water fills the unit and the undersized cubes can become lodged or stuck in the ice maker while being ejected, equally so if there is an over fill situation caused by other failures the ice maker can't eject at all. Pleazer Appliance...
Ejector fingers
Ice Stripper
Apr 17, 2014 | Refrigerators
Ice maker in not working
A lot of times the reason the ice maker is not working is 1 of 2 things. First I would check the water filter if the fridge has one, and make sure it is new, or replace it if it has been over 3 months (depending on the fridge and filter, could last longer). If you replace the filter and the ice maker is still not working, be sure to check the water line going into the fridge, if it is a plastic line (soft to the touch) make sure to squeeze it ever so gently to see if water is flowing through the line properly. If so then, you may need to turn the water off to the fridge and disconnect the water line from the fridge to see if it is clogged, if so it could be clogged with calcium deposits, if not then the mechanism for the ice maker it's self could have gone out and needs replaced. This all depends as well on how old the fridge is. If the ice maker has a metal bar, be sure it is in the proper position to make ice, a lot of times they get broken and need replaced.
Apr 08, 2014 | Refrigerators
The h2o light on display had no colour then turned blue now gone red fridge only 7 months old but have lost manual
The filter/water system is designed to change colors after 6 calendar months, the system does not count the flow of water (unless you have the smart valve unit that measures water). Either way, you can either reset the filter by holding the filter button for 5-10 seconds or replace the filter and hold the filter button then.
Good luck
Jul 13, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Replaced the water filter. the refrigerator is making ice but not dispensing water
Is there any packaging from the new water filter restricting the flow. Check for anything blocking the water flow near where you replace the filter and check for correct installation. If this problem was the reason you replace the filter check the switch that dispenses the water. Make sure it isn't "iced up".
Sep 30, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
I replaced the filter after 6 months, worked fine no problems. I replaced filter after another 6 months and now have no water no ice?????? All was working perfectly until I replaced the filter. I now...
My suggestion , would be to reinstall your old filter or use the bypass piece which came with the refrig . You only need to replace the filter when the water flow starts to slow down or the ice cubes get smaller . Not when the red light comes on telling you to . Manufacturers make a lot of money , due to these red lights .
Aug 05, 2009 | GE Adora (DSF25KGTBG) Side by Side...
The ice maker stopped workingand the fillter has water in it
bobdmartin
The melt arm must be down to make ice and the freezer must be at least 10 degrees to make ice, as for the water in your filter that happens if the filter is not placed in there right and you might need a new filter in which will make ice, first check the water pressure, how to do that is draw water from the front of your refrigerator if it is bearly flowing the filter has a lot to do with that so go get yourself a new filter at your local hardware store. And see what happens next.
May 20, 2009 | Samsung Refrigerators
Ice water dispenser
With respect to the little white floaters in the water, it is not bacteria but rather a problem that sometimes occurs with hard (heavily mineralized) water.
Aug 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
3,685 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
Fred Sops
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
