The flashing green light on your Epson Stylus CX3600 printer is indicating an error with the ink system. The error message you mentioned, "not to press the ink button unless the green light is on and not flashing", is likely referring to the ink button that is located on the side of the printer and is used to reset the ink levels.
To resolve the issue with the flashing green light, try the following steps:
Turn off the printer: Turn off the printer and disconnect it from the power source.
Clean the ink cartridges: Remove the ink cartridges from the printer and clean the contacts with a soft, damp cloth. Make sure not to touch the ink nozzles or the copper contacts.
Check for clogs: If the problem persists, check the ink cartridges for clogs and clean the print head.
Reinstall the ink cartridges: Reinstall the ink cartridges into the printer, making sure that they are properly seated.
Turn on the printer: Connect the printer to the power source and turn it on.
Check the green light: Observe the green light and make sure it is no longer flashing
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
It appears that this is an overseas model (at least for those here in the US that is) as far as I can tell. This will use the same drivers as the CX3600 model though. Depending on how long you have had this and how often you use it, you may have a waste ink reset situation. While I have not had any personal experience with this model, there are several references on the internet on how to do a reset. There is even an "SSC Service Utility" you can search for that lists this printer as being supported. It cannot reset the ink counters but it may reset the waste. Good luck, I hope this is of some help.
Every time an Epson printer "cleans" itself, it dumps ink into "waste pads". The printer counts up how much ink it has put in those waste pads, and will stop printing when it believes the pads are full. You may be able to reset the counter with software. Google, "epson waste counter reset" for ways to do that.
