Question about Toshiba Satellite 1805-S204 Notebook
Removing the cpu
How can i take out the processor
    Genius:
  • 2,028 Answers
Why would you want to? If you have to then go to the link below. It will give you breakdown diagrams. If you can't find it there, just start taking it apart, the cpu will be under the heat sink next t the fan, just remember where everything goes.
http://repair4laptop.org/notebook.html
Posted on Jun 24, 2008
How can i find the processor's FPO number?
It's printed on the top side of the CPU itself and on the white sticker attached to the blue box it came in (look for "FPO/BATCH") . If the CPU is built into a mainboard already and you want to check the CPU itself, you would need to remove the cooling assembly from the CPU and clean it of any thermal grease. Do *not* do this if you have no idea how to properly reapply the cooling block, just putting it back after removal will not do and will most likely destroy the CPU.
Jun 18, 2014 | Intel Pentium Dual Core E2140 / 1.6 GHz...
How can i find the processor's atpo number?
Download the processor datasheet here: http://download.intel.com/design/processor/datashts/31698104.pdf
Search the file (Ctrl f) for "atpo" to see the diagram that shows you where the atpo is printed on the processor, then open the computer and remove the cpu fan to access the cpu.
Jan 05, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
No Beep no display: Cpu fan Running.
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Dec 29, 2010 | ASUS P4VP-MX Motherboard
Overheating intel 915 2.8ghz processor 50degrees
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
I have a acer 210t laptop with a 700 processor. can I upgrade to a faster processor and if so which one and how fast. Thank you.
Some laptops have "mobile" CPUs (physically smaller, and consuming less power) than the typical "desktop" CPUs.
So, if you know "how" to disassemble your computer, you may be able to remove the heat-sink & fans on top of the CPU, remove the CPU, and install a faster one.
However, if your current CPU is of the "Pentium III" series (which ranged from 500 Mhz to about 1400 Mhz), you may not be able to find a CPU that will be significantly faster than your current 1.26 Ghz CPU.
Instead, I would check the disk-drive -- if it is 4200 RPM or 5400 RPM, I would replace it with a 7200 RPM disk-drive, for better I/O speeds, and thus help your computer go "faster".
Also, I would add more RAM, again to make your computer go "faster".
Jun 09, 2010 | Acer Pentium III , 1.26 GHz Processor...
I just bought a new motherboard; basically new everything, well on my old motherboard there was a CPU and on this newer better motherboard there is not a CPU. Do I need to got one? What is a CPU exactly?
first, make sure that the new mother board support the old Processors, ask the M.Board supplier about it (or google it) , and make sure you know the old processors type.If you wasn't really sure, just remove the old Processor from old M.Board, then check for the ID (such as Pentium 4, Pentium D, etc ) on top of the processor.
If the new M.Board support the Processors, then you can re use the old processors, if don't, then you don't have a choice, buy the new one that match with the new M.Board specifications.
Hope you understand.
Feb 22, 2010 | Office Equipment & Supplies
Take a 2-CPU Precision 670 down to 1-CPU
You probably removed the "primary" CPU,
and the computer cannot operate only with the "secondary" CPU installed.
Move the CPU from the "secondary" slot to the "primary" slot.
Jan 13, 2010 | Dell Precision Workstation 670 PC Desktop
How do i remove the processor on a dell optiplex gx 280 from the heatsink and repaste the processor seems to be like glued to the heatsink?
The heatsink compound does act as a weak glue over time. To remove the heatsink, twist gently after removing the clamps, to release the junction. The CPU should stay in it's socket. Scrape off the old compound and add new and re-install the heatsink.
Sep 23, 2009 | Dell Pentium IV 2.8GHZ Processor Unit...
Instal better processors ive one at 2.4 . i want 2 X 2.4 PROCESSORS on a asrock motherboard ,E5200 @2.50ghz, 2 gig ram,Pentium(R) DUAL-CORE CPU. How do i install this on motherboard
The CPU support list is here for you to check.
http://www.asrock.com/support/CPU.asp
If your MoBo supports the CPU you wish to fit, remove the heat sink and cooling fan, unclip the CPU and replace in the correct orientation. DO NOT attempt to force the CPU into the socket.
Also note you may have to upgrade the heatsink and cooling fan.
Sep 07, 2009 | Intel Computers & Internet
Processor
You're going to have to give us more information about what you are looking to do. If you are wanting to know how to add/remove your processor: If the heat-sink and fan are removed, there is a little clasp or lever you have to undo/push down and up to unlatch the processor. After that, you are going to VERY CAREFULLY remove the processor from the slot. If you need to add the processor, place the processor down on the CPU seating with the lever/clasp undone. Make sure you line up the arrow on the corner of the CPU to the arrow on the motherboard. Press the clasp/lever down and latch it into place.
Feb 09, 2008 | ASUS VIA 694XDP Dual Processor Chipset...
Toshiba Satellite 1805-S204 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
