Question about Sony KP-46WT510 46" Rear Projection HDTV
Unable to resolve concave issues
Problem occurred on 5/29/08. Picture looks curved. Upper left corner and lower corners appear reddish/pink. Green lines /Ghosting appears on screen. Double lettering. Is this something that we can fix ourselves? We have done the Flash Focus and manual Convergence adjusting with no change in picture. Thanks,
  • 2 more comments
  • rfor23 Jul 04, 2008
    Just happened to mine...red / greenish hue and skewed, concave-like corners curling off of the screen. Would much rather try to get this fixed than buy a new tv..any suggestions would be appreciated.
  • Anonymous Jan 05, 2009
    My sony 61 in. has the curved picture at the top corners. I trtied adjusting the convergence, but it only moved the colors and not the picture.
  • amitag Jan 26, 2009
    in my tv double lettering and picture is coming with red and green color.can u help me to solve this problem
  • mnorma1 Feb 28, 2009
    I had the same problem with my KP-46WT510. I called around locally and all repair shops knew what needed to be repaired after I explained what was going on, but all wanted $450 to $500 to repair and I had to take the set to them. I was unsure if it was worth fixing until I found this site. I contacted a gentleman at www.TvRepairKits.com and he was excellent in helping me with the repair. I ordered the convergence repair kit. After checking out the fuses and resistors, I replaced the convergence chips and one 3.5 pico fuse. I was lucky that I did not have to replace any of the resistors. I did buy a Radio Shack de-soldering iron (highly recommend getting this) and it was a simple repair. My TV now operates like a new one and my cost was about $85 and about 1-1/2 hours of my time. Please do not be afraid of fixing your set.
  • Sony Master
  • 3,459 Answers
Tips
1) Replace the Convergence Chips with factory original Sanyo brand chips.
2) Examine the convergence resistors - replace any that look burnt.
3) Check the pico fuses - 3.5 amp - and 5amp - replace any that are burnt out.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, pico fuses, etc. Everything you need to fix it yourself. Its an easy fix.
Posted on Jan 26, 2009
  • Edward
    Edward Mar 13, 2009
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I am also having the same problem. I tried to replace ICs but no luck. I am also looking for service manual in case if some one can give it to me.
Thanks,
Sanjay
Posted on Jun 26, 2008
Can't bring into focus the entire image. Corners defocused and have green/purple halos.
If it is a known problem, then it is a manufacturing error. They have just admitted that is a MISPLACED washer. Have Optima repair it free of charge.
Mar 28, 2017 | Optoma Office Equipment & Supplies
Hitachi 53udx10b issue with green and pink lines creeping in upper left corner of picture. Rear projection tv about 10 years old. Just started yesterday, didn't have any problems prior.
thath is your converce pin corner are missaligned
usely behind the front bottom panel you will find a board with some knobs for ajustement off the convergence watch to not turn every control its gone a be disaster /when you find the control panel look
for the adjust button in one off the corner usely red
if you pressed the crosshatch will appear in the screen/ watc to dont touch any electronic or tube there is a lot off highvoltage in there use care
when you got the crosshatch pattern read carefully
wich control act onthe left corner
beware about the highvoltage its dangerous if you
not shure ask someone who have knowledge about this
hope that will help you BE CAREFULL
Mar 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
PINK/GREEN SHADOWS, LINES
Here is what I was able to find out about your problem from sony: This issue is usually caused by some type of nearby magnetic interference, such as unshielded stereo speakers placed too close to the TV. These spots can be small or large and will normally be red, green or blue, but sometimes appear purple or pink. They normally occur on the sides or corners of the screen, but can also appear in the middle. To resolve this issue, move any stereo speakers or other electronic devices away from the TV; a minimum of 2-3 feet is recommended. If the situation is not remedied immediately, unplug the power cord of the TV from the electrical outlet for 20-30 minutes; repeat this process one more time if the issue is not resolved the first time. If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer in your area. Hope this is helpful:)
Sep 04, 2007 | Sony KP-57HW40 57" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Meaning of Green square icon on upper left corner
I have the same camera. The green square icon appears while the camera is saving the picture. From your description, I think you were using "Shot Confirmation", and this setting was cleared during the repairs. Have you tried going into the Setup mode (on the dial) and reselecting Shot Confirmation? (p. 143 in the manual)
Jan 17, 2007 | Nikon Coolpix 5400 Digital Camera
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
223 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
