Question about AudioBahn Car Audio & Video
Repair, Replace i have a pair of some pretty good 6x9 speakers for my car and both of them have "blown" voice coils. how can i replace them, where can i get the parts or who can do it for me? i dont have the money to get knew ones will it be cheaper to fix or buy new speakers? Audiobahn 2way 6x9 car speaker "AS69Q"
  • manpee1 Jun 24, 2008
    well the cones , frames and diaphram are all in "like new" condition they just have blown coils. cant you just buy new coils?
  • 109 Answers
Fixing them isn't worth it just purchase some new 6x9's for less.
Posted on Jun 24, 2008
  • InVision_A_V Jun 24, 2008
    Negative. In order to replace the voice coils you have to replace the whole cone, diaphram, and spider. Replacement is much cheaper and you can get something better for less anyhow.
Blown speaker
Your best bet here would be to contact one of these authorized dealers for advice I think.
-Steve
Find Service Center
Nov 14, 2013 | Behringer B1520 Pro Eurolive 15" 2-Way...
I have a pair of Cerwin Vega LS 15-series home speakers. One of the subs stopped working but still has sound coming out of the voice coil. Do i need to replace the sub?
You need to check the connections on the cross over board and also Ohm out the speaker to see if the voice coil is open. If you cannot get the same woofer, then you should replace them in pair, try http://www.parts-express.com//index.cfm?
Feb 25, 2011 | Cerwin Vega LS-15 Speaker
Can I repair a blown(frozen) s-12?
yes- though i have never done it myself.
frozen woofers are often the result of melted vioce coils. here is a site for a company which sells alpine voice coil repair kits: http://www.mwaspeakerparts.com/speaker_parts_manufacturers.html
here is a page which details how to repair voice coils yourself: http://www.sound-thinking.org/index.php?showtopic=908
Oct 27, 2010 | Alpine SWS-1240 Car Speaker
Blown voice coils
Well the voice coil is a basic electromagnet. Electromagnet is a coil of wire, usually wrapped around a piece of magnetic metal, such as iron. there are many things need to keep in mind while replacing the voice coil like - wire size, length, type...... usually the speakers not works good after replacing the voice coils and replacing the speakers is the better option regarding money..... anyway you can please tell us the type or model of your speakers if you need more help or information........
Good Luck!!
Thanks
Jan 29, 2010 | PowerBase Car Audio & Video
How do i get to the voice coil in my 10" xplod? im pretty sure its blown but i wanna take a look.
its behind the magnet but you cant replace just the voice coil you need a whole new speaker
Nov 21, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Voice commands are garbled to the point I cannot understand.
most likely the speaker is blown internally! Try with a headphone and see if that fixes your problem. If it does you can buy a cheap external speaker for any headphone style jack to use!
Jul 18, 2009 | Magellan Maestro 4040 GPS Receiver
Seals around speakers are broekn and gone!
Hello kagato_morri,
While it's certainly possible to replace the surrounds, whether it's economical to do so is another question. For very high-end speakers, there are often "repair kits" available to replace spiders, cones, surrounds and for some, even the voice coils. But such parts are usually not available for your run-of-the-mill speakers.
If the speakers are otherwise in good condition, and you are willing to spend some time with them, you can use an adhesive foam to construct a new surround. A product called "shoe goo" makes a good permanent bond. It's a super strong rubber cement and will hold up under the stresses of the moving speaker cone.
Hope this helps.
May 23, 2009 | JVC Car Audio & Video
Blown subwoofer
"Is there any way to repair voice coil?"
the simple answer is no.
the long answer is you could try contacting the mfg of the sub and see if you can order a new foam ring, cone and voice coil to replace the one you will have to destroy to take it out.
Nov 09, 2008 | Jl Audio 12W3 Car Subwoofer
Tweeters????
Hi oddone
You may have a problem with either blown tweeters, or a faulty cross over, or both. If you have a multimeter, you can remove the tweeter, and check it DC resistance. They normally have their impedance marked on the back of the magnet. If not, you can assume they should measure 8 ohms. If they measure open circuit (high resistance), then they have failed.
A good speaker repair guy can often fix an open circuit tweeter as they often break where the very fine wires attach from the voice coil to the terminal. you can take a turn of the voice coil and reterminate to solve this problem. If the voice coils are burnt, they will need to be replaced.
If the tweeter meters ok, then you may have a problem with the crossover capacitors going dry. Generally they are 2.2uf to 6.8uf in value, the smallest cap in the crossover. If the plastic coating on them is split, or they look a different colour to the rest of the caps, replace them, if they sound "hollow" replace em, if you are not sure, replace em. other than that there is not alot more to look for with a speaker box tweeter Good luck and happy listening.
If you have any dramas, get back to me here and we can talk more about it.
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
Repairing BOSE 901 IV series speakers
The grille will come off if you try to pry it off. Then, unscrew the bad driver. Sort of new ones are sold on E-Bay for not a lot of money. Install the new driver, secure it with screws, and snap the grille back into place.
Apr 24, 2006 | Bose 901 VI Main / Stereo Speaker
Car Audio & Video Logo
85 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
