Question about Rockford Fosgate P3001 Car Audio Amplifier
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
I just had my new amp, sub and speakers installed yesterday. when i have my car stereo on the radio the sub amp and everything work just fine, but when i turn it on the cd function to play a cd there is no sound coming from the sub like the amp has completely powered off. i looked at the amp when i was just listening to the radio and the blue power light was on and it all worked fine then i switched it over to the cd player and the blue light went off and the amp completely powered itself off. i have a rockford fosgate punch amplifier P300-1. CAN YOU HELP PLEASE?!!!!
  • 1 more comment
  • eenloe Jun 24, 2008
    OMG thank you so much. Its been driving me crazy there is never anything good on the flippin radio. and cds sounded awful!!! THANK YOU SO MUCH AGAIN!!!!!
    it didnt work :-(
  • jdsurely Jan 29, 2009
    I am having this exact same problem, and I am 100% sure that I spliced the correct wires. I spliced the REM to the REM/Antenna wire in the harness. I also just double checked to make sure that was correct. Any new ideas?
  • 109 Answers
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Posted on Jun 24, 2008
4 Suggested Answers
  • 182 Answers
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
Professor_V
  • 92 Answers
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
SUBS NOT WORKING WITH THE CD OR aUX
Since the subs work with the radio, then there is nothing wrong with the speakers themselves. The issue must lie with your radio or control unit.
Jan 20, 2014 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Can I hook up an amp and subs to a 98 pontiac gtp factory delco cd player
Yes, you will need to purchase an adapter for an ac delco radio that has rca jacks to plug your amp into
Dec 24, 2010 | Car Audio & Video
The woofer wont turn off
The only wires that should be going to the subs are the Speaker wire, The power, goes to the amp, Blue the remote wire should only go to the remote spot on the amp wich is usually labeled rem. and the ground all goes to the amp.
Nov 19, 2009 | Vibe CBR10 Car Subwoofer
Subwoofer Help
check the amp. the "switches" gain,bass boost...etc they might be over powering your subs and heating them up. if those are fine then you mite want to try your subs on another amp...it migt just be that the subs are easily over heating.
Aug 26, 2009 | Rockford Fosgate Car Audio & Video
Subwoofers work with radio and not cd player
You have mistakenly used the power antenna remote wire for the amplifier remote wire. When the FM/AM source is de-selected, the signal drops from that wire so the power antenna will go down.
Switch the 2 blue wires and you will be problem free.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 22, 2009 | Alpine Car Audio & Video
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Troubleshooting in car cd player
that is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Nov 06, 2008 | Sony Xplod CD Player w/MP3 Playback...
Hooking up a subwoofer
If your head unit has speaker outputs, and RCA outputs, it should be able to use them at the same time. Turing off th internal amp is just to save power and heat if you aren't using it.
May 23, 2008 | Alpine CDA-9883 CD Player
Amps wont stay on
try to look at the connection on the back of the cd player and make sure that the amp power wire is connected to the power wire on the wire harness on the back of the cd player and that should work but i only need one amp for a pair of 6by9s and subs try to bridge the speakers all to one amp that should cause it to sta on while in cd mode hope that helps
Dec 26, 2007 | Kenwood KDC-MP435U CD Player
Speaker Problems
If you are unplugging the subs from the aux output at the cd player, your Audio lines feeding the amps is shorted somewhere between the cd player and Amps.
Nov 13, 2007 | Car Audio & Video
Rockford Fosgate P3001 Car Audio Amplifier Logo
1,784 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
