Question about Goldstar Televison & Video
No movie picture
To whom it may concern:
The actual VCR is functional, but the movie will not show on the tv screen. I need to know which wires to look for and where to plug them in.
Also, should I connect the VCR with the cable box so that the tv screen does not go snowy everytime I press the VCR power button? How?
Thank you,
Jacqueline
Bronx, NY
    Sergeant:
  • 260 Answers
If you want to record from cable to your vcr the usual configuration is either cable to cable box, cable box to vcr, and vcr to tv. If you want to get rid of the snowy pictures, you can plug the cable box directly to the tv and separately to the vcr, and you can also plug the vcr into the tv. but the tv has to have two inputs
the best configuration will be the black, screw in, coaxial cable from the cable box to the television and the red, white and yellow RCA plugs from the cable box to the vcr in.
then the vcr our red whit and yellow cables to the back of the tv.
To watch vcr, switch the tv to video mode
to watch cable, switch tv to channel 3 or 4, depending on the cable service.
please let me know if you have questions.
Ken
Posted on Jun 24, 2008
My TV/VCR combo is not showing the picture of my movie in the vcr. The picture is snowy, but there is audio of the movie. Do you know what the problem is?
try changing the channel from 3 to 4 or vice versa. You will usually get sound but no picture if its on the wrong channel
Dec 03, 2010 | Orion Televison & Video
We were just watching a vhs movie on our tv/vcr combo unit and the picture went to fuzz however, the sound was still working. any suggestions or are we in need of a new unit.
Some VHS have a tracking button that allows the user to tune to the best signal. Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
Jun 23, 2010 | Memorex MVT2135 13 in. TV/VCR Combo
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
Apr 29, 2009 | Sharp Aquos LC-32D40U Television
My dvd home theater sound system is saying mode not supported i
the tv HDMI point is faulty becourse i tried it from other point and is working fine, thank you for your concern.
Jan 29, 2009 | Panasonic 600W DVD+VCR Home Theater System...
Connections
Without the manual !!
1)VCR INPUT:: [Cable_antenna In] the coxial screws on from "output" of cable box or ( airwave )antenna.
2) VCR output:: connect another coxial into input of TV. You should be able to keep all the other wires connected from SONY theater system.
note:: your VCR has a switch for VCR\TV. When u have a VHS tape playing a movie & switch from VCR to TV, you will see the channel that is on the VCR not the cable box\ antenna input.
example:Cable channel is on Ch.122, & your TV must be set to Ch.3 to view cable.If your VCR is set to Ch/5 you may not see that Ch.122.You will still be able to see your VHS tape when u place the VCR\TV switch back to VCR.
I am going to share wt.u a $100,000,000.00 trick:put any ch.on cable box.Switch VCR\TV to TV,change channel ON VHS tuner.When u come to the [picture] that the cable box is on,Then that is the Ch.u can see cable ON the VHS.
U owe me!!
Jun 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Samir
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
How to show images on my TV or VCR
Hi connect rca cable to tv , rotate knob to play mode press function set and press play ,now you can view movie.
Jan 24, 2008 | Canon PowerShot A530 Digital Camera
My dvd/vcr promblem
Neen codes to program in my remote
Dec 26, 2007 | Daewoo DV-6T834 DVD Player/VCR
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Feb 03, 2007 | Panasonic CT-34WX54 34" TV
Televison & Video Logo
116 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
