Question about Toshiba TZ50V51 50" Rear Projection Television
Toshiba blinking red light
Sounds like i have a similar problem with a toshiba 51" projection tv with a shutdown and a blinking red light ...any help would be greatly appreciated....thk you
  • 6 more comments
  • Anonymous Jun 28, 2008
    sAME PROBLEM HERE! I TRIED TO TURN IT ON IN THE AM AND IT "CLICKS"LIKE IT SHOULD BE WORKING BUT - NOTHING AND THE RED LIGHT JUST BLINKS. sOUNDS LIKE THIS IS A PROBLEM ON ALL OF THE PROJECTION TVS! mAYBE TOSHIBA SHOULD BE LOOKING INTO THIS
  • christaheap Aug 24, 2008
    same problem as others described. tv turns on like it should work, no picture or sound, just the blinking red light. you can't even turn the t.v. off or get the light to quit blinking without unplugging it.
  • INDIAN2003PP Aug 29, 2008
    How do you solve the blinking red light problem on the Toshiba TZ50V51? The service manual you suggested is no where on the site you suggest. Looking for help.
  • lindaschlarb Sep 04, 2008
    Having the same problem, turn the tv on and it turns itself off with a blinking red light. Have to unplug it to turn it back on sometimes multiple times before it will stay on.
  • bpgi Sep 17, 2008
    I turn my TV on and after about 30 seconds it shuts off. The power button light on the front of the TV just blinks. You have to unplug the TV and plug it back in to get the light to stop blinking. In the beginning when this happened the TV would work and now after a few months it only stays on for 30 seconds. Somebody help! My husband loves this TV on football Sunday
  • hiff Oct 04, 2008
    light flashes when turned on
  • michael leblanc Oct 08, 2008
    YES i DO HAVE THE SAME PROBLEM i CAN ONLY GET THE LIGHT TO STOP BLINKING BY UNPLUGGING IT THEN IT COMES BACK ON BUT ONLY FOR ABOUT 30 SECONDS OR SO WHO CAN FIX IT OR WHATS THE PROBLEM .oR IS IT EVEN WORTH FIXING SHOULD I LOOK FORE A NEW ONE!
    RE:TOSHIBA 50" PROJECTION TV
  • Anonymous Oct 27, 2008
    whats the solution.
I had the same problem with the red light blinking, either pull the plug and let it reset for 24 hours
or check everything in the back of the tv and come to find out my fused and some wires were loose.
problem solved..
Posted on Oct 31, 2008
MI TELEVISON PARPADEA LA LUZ ROJA Y SE MANTIENE EN ESTADO DE HINBERNACIóN
Posted on Sep 28, 2008
YUp i have the same prob 2 How can We fix it?
Posted on Sep 14, 2008
My toshiba theaterwide hd 51h83 no picture no sound when plug in blue screen come on then go off in 3second then red light next to power button blinking no picture
call toshiba customer care. Seems like software issue. I had the same. I was told to put 2 special files on a usb drive, connect it to tv, to reflash to tv software. it came back to life after that.. just try..
Nov 23, 2012 | Toshiba 51h83 51-inch Hdtv-ready...
No picture comes up but tv powers up and the stand-by light blinks for about 3 to5 seconds, i also hear sound when i turn it on and change channels
If in shutdown the power light should continue to blink a specific number of blinks which is a error code.
This set is prone to bad picture tubes (has 3) so depending on code may be a fatal issue----sets will before flash bright red, green, or blue when this happens and shut off.
Jun 14, 2012 | Sony KP-51HW40 51" Rear Projection...
Have an older Toshiba theaterview TV, when turn on, we have no picture, no sound, just black screen and blinking red light that just continuously blinks.
Theaterview suggests a rear projection--in that case it most likely is in the convergence circuit--unsolder chips (convergence) and see if set turns on.
Some of their regular TV sets (picture tube) if the light is just blinking means the same thing=shutdown because of a short/problem but a model number would tell me which you have.
May 23, 2012 | Toshiba Televison & Video
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Click when plugged in and steady blinking red light.
hello it sounds like it could be just a dry joint on the video section of the tv good luck
shaun
May 27, 2009 | Toshiba 43HX71 43" Rear Projection...
Red light Blinks
your set is shutdown for protection due to an audio malfunction in the audio circuits. heres the info for your model from the service manual.
• + or - 22V audio supply is not
present—Check PS600 & PS601
• Audio AMP is damaged IC601 on
A Board
Apr 06, 2008 | Sony KP-51WS510 51" Rear Projection...
Toshiba
possible color wheel is faulty,call a service shop for an estimate of cost.
Dec 07, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Toshiba projection tv
Unplug the TV from the outlet for about 30 seconds. This will reset the microprocessor. Re apply AC and power on the TV. If your lucky the set will come on and play. If not, the red light will start blinking again indicating shutdown. There are many reasons for the set to go into shutdown, but one of the most common cause is failure of the convergence output IC`s. If your TV is in shutdown, you will need to find a qualified technician for proper diagnosis and repair.
Nov 23, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
656 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
