Question about Frigidaire FRS23H7C Side by Side Refrigerator
WARRANTY I AM TRYING TO FIND OUT HOW LONG IS THE WARRANTY ON THE COMPRESSOR. MY COMPRESSOR NEEDS REPLACING!
  • 1,531 Answers
It is up to a five year warranty on the compressor.
Posted on Jan 22, 2010
Freezer is making an on and off clicking noise. and making lights dim
The compressor is trying to start and going off on overload that is the clicking noise you are hearing.... Also the compressor is drawing high amp which is what is causing the lights to dim.....You have a compressor that has a locked rotor or the start components are bad....
In either case if you can't get a service tech to come out right away you will need to unload the freezer.... because the compressor is not working which is what the freezer uses to make it cold...
When the service tech checks it out he will be able to tell you if he can get it to work by replaceing a capacitor or the Compressor is not repairable.and that he will have to replace it..... which is a major repair.
If the freezer is old I would recommend buying a new one...... You will get a new 5 year warranty on the compressor and if you replace the compressor you will get only a 1 year warranty.....
May 30, 2011 | Kitchen Ranges
New outside compressor 4 ton Ruud 13 seer unit.
Sounds like a compressor needs to be replaced. You will need a service tech to make sure of it. Sometimes the compressor can work for a long time that way. Check your warranty. Usually compressors will have longer warranty on it.
Jul 25, 2009 | Heating & Cooling
Compressor Problem WeatherKing 13AJA36A01
Your warranty on your WeatherKing is five years on the compressor. When you buy a compressor to go in your unit it is 1 year. Several resons for bad valves. Dirty evaporator coil, overcharged and bad evap fan motor. James
Jul 10, 2009 | Heating & Cooling
Need to replace 3 ton compressor
Depending on age of the unit. The compressor amy under warranty. The replacement is something that should be done by a service tech. You have 3,5 ton unit Rus
Jun 14, 2009 | Ruud UAKA042 Air Conditioner
Does my 10-seer have a 10 year compressor warranty?
If you take all the numbers off the compressor and condesning unit and call an authorized RUUD parts dealer in your area, they should be able to verify your inquiry.
Unless there was a special circumstance, most compressor warranties are 5 years, unless the compressor was replaced during the 5 year period, in which case you should get 5 more years assuming the service was performed by an authorized service company.
May 19, 2009 | Ruud Matching Split Air Conditioner
Beverage air single door freezer compressor
OH well that's a real easy question to answer.
All the compressor manufacturers have a 1 year replacement warranty (just on the compressor). Any labor freight and mils like driers, freon, cleaner ... items are not covered.
Now you may be able to purchase an extended warranty for up to 5 years total. Some contractors offer their own warranty for extension. But ask yourself how much is it really worth to have ? Extended warranties are an additional cost and is not under the manufacturers warranty. So for the 1st year its the manufacturer anyway and on some manufacturers (Copeland) it is limited to 3 compressors total within the 12 months. So an extended may also be limited withn the 5 years.
And if your loosing compressors from 2 different causes, 1 electrical and 1 mechanical. And if the initial problems were inerrant in the compressors individually, the likely occurrence in the next 5 years is really remote in my opinion. Assuming the coil is kept clean and grease and paper is not allowed to block the condenser air and the defrost doesn't go haywire, and the electrical to the unit is kept within specifications and the replacement compressor was given a new drier clean refrigerant and maybe some acid cleaner.. But to me $700.00 for a whole job on a fractional compressor sounds really, pardon, cheep.
The reason is that if you hve more than 3 failures something else is causing them besides the compressors. (And I contend to agree). I have only had 1 compressor job that kept failing year after year. And the incompient rebuilder (Owens Hermetic OKC) kept rebuilding the same compressor body except for the 3rd time I talked the owner into getting a remanufactured one and that was because I took the old one apart and found the cylender walls scored and therefore the piston and rings were not sealing. And every winter the refrigerant would migrate into the compressor on the first cold day and boom no compressor.
Extended warranties (as far as i know) from an outside warranty company may not be as good as the paper it is written on. in other words I have seen 2 warranty company go belly up within the past 25 years. But not within the past 10.
Hope this helps answer your question. Let em know If I need to tell you more. If I helped you please give me as high a rating as you can. Thank you and good luck.
Mar 20, 2009 | Kolpak WARRANTY-2HP 5 Year Walk-In Freezer...
I bought a Frigidare refrigerator today. Warranty needed?
its really just up to you. I am a service tech in grants pass oregon and i know compressors dont last anymore. Its because in the last 10 years they have switched from r12 freon to 134a. 134a has higher head pressures which make the compressor go out. If the compressor warranty isnt too much money i would do that warranty. You dont really need the others.
Jan 29, 2009 | Frigidaire Refrigerators
WeatherKing Unit needs compressor and is under warranty
have you contacted the company who installed ? try there first, if no luck with the company, contact the manufacture directly, explain to them your problem and try to have them help you with getting the company who installed to do the right thing and replace the compressor under warranty, you may have to pay a warranty install charge, but it would be alot less than having to pay for a whole new compressor, or new unit, put your ducks in a row, get model and serial numbers, date of install, who installed it, and the manufactures warranty on the compressor, that way you will be ahead of the game, best of luck, hope that helped
Jan 19, 2009 | Heating & Cooling
Weather King 10AJA6001AH Air Conditioner with bad compressor
If it is five years old it is either right in or out of warranty a service tech can determine this through the serial number. If not the unit is only a little bit more to replace than the compressor. A replacement compressor is only warrantied for one year verses a unit replacement with five years on the compressor and one year parts and labor.
Oct 04, 2008 | Air Tools & Compressors
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Frigidaire FRS23H7C Side by Side Refrigerator Logo
200 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
