Question about LG 24 in. LDS 5811 Built-in Dishwasher
Era codes What are the era codes for a LG Electronics model LDS5811BB
  • Anthony Patrick Jul 01, 2008
    Error code "PF" is not listed in the LG manual. It means Power Fault and indicates that there is a problem with the power. With the LDS 5811 this may also be due to a failing wiring harness, failing connectors on the PCB (being contaminated by black goop from the back or the door), etc. Older versions of the LDS 5811 "leak black goop" into the electronics and wiring harness behind the door causing failures, overheating, poor cleaning, etc.
  • Richard Lew May 11, 2010
    What are you trying to do?  The error codes are listed in your owner's manual.
ERROR CODE LE
Posted on Feb 11, 2009
  • 489 Answers
The PF code means that there is a power problem with your unit. Make sure that you're not having issues with your outlet.  Check the connection at the junction box to make sure they're good and tight.  If both of those check out ok, open the front panel of the dishwasher and check the wiring harness there.  About 1/3 of the way up from the bottom of the door, inspect the wire harness for any signs of cracks or breaks in the wire.  Repair the damaged wires and that should take care of your PF issues.
Posted on Jul 23, 2008
LDS5811BB LG dishwasher IE code. What does this mean?
WATER INLET ERROR Water has not reached to the pre-set level within 8 min. since inlet valve operated, or water has not reached to the normal level within 25 min. stop cock turned off, faulty inlet valve.
Sep 19, 2014 | LG Dishwashers
Are there any service bulletins available for the LDS5811BB LG dishwasher?
Yes there are several bulletins for this model number and for different years.
Jul 19, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
Drying cycle vents at bottom of door causing a slip hazard
call the manfacturer and give them give them make model and year of machine.If problem they may be aware of it and should be able to help you
Dec 16, 2009 | LG 24 in. LDF 7811 Stainless Steel...
I have an LG Diswasher LDS5811BB Bought in 2006
LE is a motor error The Motor is working abnormally.
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Aug 29, 2009 | LG Dishwashers
LG dishwasher won't dry
Recommend you confirm that the rinse aid is not empty.
If problem persists and you are not getting an error message, contact LG service and pres them for the retrofit they released for the LDS5811 (and other models) that dramaticly enhances the drying ability. Until it is replaced, be careful because it is possible tht water will leak from the door panel (not directly from inside the diswasher, but through the door panel-based drying system.
Press them for a no charge repair for this problem and be persistant, firm but polite. If the agent is not helpful on their own, request to be "escalated" to his/her manager. Good Luck! and report back what you find. Thanks!
Mar 29, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
I need a remote control, or need to know if my universal remote w
I just discovered this site because my remote just quit as well. Here is the direct link. http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6710CDAL01C/New.aspx?ModelMfgName=LG+Electronics+Incorporated&ModelBrandName=LG+Electronics%2fZenith&ModelNumber=DVT412 Not bad price either.
Jan 20, 2009 | Zenith DVT412 System
Door hinge adjustment to LG Dishwasher
There is no adjustment to the door hinges. If your hinges are failing they will need to be replaced.
Jan 06, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG WM0532HW
I found a part number for a switch: http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6600FA1704X/New.aspx To see the full list of parts for this model: http://www.partstore.com/Model/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW.aspx
Sep 02, 2007 | Washing Machines
LG 24 in. LDS 5811 Built-in Dishwasher Logo
701 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
