Question about Dryers
Dryer is not heating timer does not appear to be moving on an Admiral Ultima Dryer
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 24, 2008
  • David Emmel
    David Emmel Jun 25, 2008
    Hullah,
    Just checking back to see how you are coming on the no heat issue. I forgot to mention that the timer issue should resolve itself once you take care of the no heat issue.
    Thank you,
    Dave E. (Illeagle)
TIMER NOT MOVING AND WANT GET HOT
Depending on the model and type of dryer in question this type of issue is usually the timer motor. Most are a part of the main control module and cannot be replace individually. Hope this helps
Mar 16, 2016 | Admiral Dryers
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Admiral dryer wont dry clothes
one of several things can cause this . contacts in the timer , heating element ,door switch to name a few .plugged lint filter also can cause poor drying as it slows the air flow .when all else fails call a service tech
Mar 13, 2015 | Admiral Dryers
Admiral Dryer, runs bu t does not heat
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Nov 17, 2014 | Admiral Dryers
Admiral dryer timer not turning and no heat
It could be the high temp fuse on the element and the timer not turning depends doyou have it on the auto dry because it will not advance if it is not heating because the sensors are not detecting a decrease in the humidity levels because the element not working.
Mar 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
The dryer runs but does not turn off i replaced the timer did not solve problem. the timer moves but on the last minute it does not shut off
I would guess venting may be restricted, remove vent tube and run dryer see if it turns off. I did find some information on a different site, here is the link, Good Luck Tim:
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/3957-maytag-dryer-wont-stop-running.html
Jan 14, 2011 | Kenmore Dryers
Hotpoint ultima logic sensing condencer TDC62 is not drying clothes, it doesn't appear to be heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Dryers
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
154 people viewed this question
Top Dryers Experts
