Question about GE Profile JTP18 Electric Single Oven
Frigidare wall oven pleb30sccc
Oven will not work with power hooked up the control board flashes off and on when you open the door or when you press bake time it gos blank press clear and the time flashes and the oven will not work
I ran a new lead wire copper new breaker from a new breaker box it was alum wire i guess it was droping amps on one lead
Posted on Jun 25, 2008
F10 code flashing on my frigidare oven
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electricrange cavity and relay it to the oven's main control so it knows when to shut off the heating elements.
Hope this helps
Bob
Sep 15, 2017 | Frigidare Ovens
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
Oven lock motor frigidaire stove close and open continuously- flashing door lock light
Hi Chris -- if I am understanding you correctly, your door lock is stuck with the door open. If this is the case, locate the oven door light switch that is typically in the top left corner of the unit. Press and hold the switch button in for about 30-60 seconds. While you're doing so, look for a flashing light on the control panel next to the word, "lock". If the latch hook is in the locked position, continue holding the button and press the CLEAR/OFF key on the control panel. Hold the button in until the flashing light goes off. If this does not resolve the issue, please supply your unit's model number and any additional symptoms it was experiencing prior to this event so that I can be of more assistance to you. - Best of Luck!
Aug 27, 2012 | Frigidaire Ovens
I have a Kenmore smooth cooktop electric range. It is about 3 years old. Recently i used the self clean function, and since then I can't get the oven door to unlock and I'm getting a F5 code on the read...
Press the "Off/Clear' button to cancel anything on the display, and reset the oven. This is a soft reset and will simply get you out of any program you have started. If the problem still persist,
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the oven back into the wall power supply to reset any anomalies with the oven memory.
Mar 02, 2011 | Kenmore Ovens
While baking we are getting error F 95 on our kenmore elite wall oven
Sorry to read about your problem, I hope this helps you out.
your f95 means your Door motor mechanism has a failure. The motor does not stop rotating.
Press stop key. Turn off power for 30 seconds then turn power on. If the door lock motor never stops rotating, or if the F95 error comes back again, verify wiring of the motor. if wiring is good, replace the EOC. If the problem persists, replace the motor latch assembly.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Ovens
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
GE JGBP80 oven shuts off and the locked door light flashes
That's awesome! I just found this site on Christmas day minutes away from family arriving and I had exhausted the manual for help. Under the troubleshooting section of the manual it lists "door Locked" light blinking as a problem with the only solution being - "shut the door." With three dishes in the oven that didn't help!
I took the advice of the site and wiggled the actual door lock on the inside of the oven and that didn't work right away either.
I had to trick the oven into thinking the door was shut by pressing the sensor on the right hand side in and then turn on the oven cleaning cycle with the sensor held down. After the lock activated and moved across with the door open, I had to hold down the door unlock feature and wiggle the lock as it unlocked. A little more complicated, but none the less it worked!
It must be a sensor inside the locking mechanism that isn't reading the lock being open - or something...
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
Kenmore 790 Oven Locking mechanism problem
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
73 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
