Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
All terrain steam vac
The steam cleaner is not dispensing any water or detergent.  Brushes are moving, the supply tank and recovery tank are brand new.  Something is plugged up and I don't have the manual available at this location.
  • 121 Answers
Try and trace the hose back from the brushes to the pump. The hose could either be disconnected, kinked, or clogged.
Good luck - Tech101
Posted on Jun 24, 2008
  • Justin Jun 24, 2008
    One other thing. If the hose is clogged you can try and use an old coat hanger and unclog the hose with it. After that you can flush the hose out with water from your sink.
How to clean brushes on hoover steam vac?
Hi, it's Allie from Crucial Vacuum!
Cleaning the brushes on your unit is a very easy and important tank to do! Your deep cleaner is equipped with removable brushes for easy cleaning. First, make sure to remove the clean water tank and recovery tank to prevent possible leaking. Tilt your unit backwards making sure the handle is in the upright position. Grab the brushes and pull firmly. You may clean the brushes with running water. Do not forget to check the brushes for any tangled hair strands or debris that can prevent the brushes from spinning properly.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 21, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
I have the SAMSUNG WA80V3 washing machine and I have tried many detergents but they all clogg. I also put a filter but still the problem remains. Is it the water quality? I live in Oman.
see the causes and fix it. God bless you
stopped spraying. If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly from
  • Sep 22, 2012 | Samsung CASE-DETERGENT;WA80V3 -...
    I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
    The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
    Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
    Hoover steamvac not picking up water
    you don't have the recovery tank lid on correctly.
    Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    Every time i push the steam vac forward it dispenses water
    you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
    Godbless and Goodluck the way just in case you dont have it here is the manual for your model
    Jun 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    How do i attach the upolstery attachment?
    Go to Click on carpet cleaners. Click on steam vac all terrain. Click on Learn more. Click on Download Instruction manual in pdf. It explains all. The hose is attached on the front of the recovery tank. under the hoover symbol.
    Jan 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Hoover steam vac model F5853-900 series 17.9
    Make sure that the recovery tank is completely close.
    Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    Hoover terrain steam cleaner, brushes wont spin
    The primary problem is that the turbine is seized. One way to verify this is to try to manually move the brushes by hand (with it off, unplugged). If not then your problem is with the turbine. This usually requires professional service. I would recommend to take it to a trusted vac shop which is familiar with these cleaners. or go to the hoover web site to locate a hoover dealer near you.
    Jul 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    How do I work this dam thing?????
    How do I work this?
    Bissell 1699 ProHeat Clear View Upright Steamer
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
    The Bissell has a holding tank to the solution and the recovery tank for the water and soap you pick up -- -both are removable for cleaning purposes – there is a trigger assm on the handle to release the Bissell Soap or detergent that you are using – (low sudsing) and there should be a switch on the bottom of the unit to activate the revolving brushes. So the best way to shampoo the rug is to do it on the back pull – when you pull back you are dispensing the water solution and shampoo by squeezing the trigger assm, the brushes are agitating the carpet and the vacuum part is picking up the water. This is about as simple as I can get it – please refer to the owners manual for the trouble shooting part of the manual or check with your local vacuum cleaner dealer in your area and in the yellow pages under vacuums, or call the Bissell factory phone # or use the website. By Phone Customer Service:
    (800) 237-7691 Hours:
    M-F 8:00 a.m. - 10:00 p.m. ET
    Saturday 9:00 a.m. - 8:00 p.m. ET
    Don – The Vac man
    Apr 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Problems with the Hoover Steam vac Heated carpet cleaner
    The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
    Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
    Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
    280 people viewed this question
    Top Hoover Vacuums Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
