Question about CTX Optoma EzPro 600 Multimedia Projector
Projector Cable I'm trying to find a cable for a CTX EZPro projector. 1 end has a VGA male connection with 3 row of pins (4 of the pins are empty), and the other side is a female connection with 2 rows of holes 8 over 7. I can't seem to find this anywhere! Any suggestions where I can find it?
  • Anonymous Jul 16, 2008
    same problem here, searched e-bay for vga cables cant find one for it, having to make to with the svhs connection
  • Andrew Piotrowski
    Andrew Piotrowski Sep 28, 2008
    Same trouble. No cable. Is there a remote for this?
    Habit-Forming:
    Scholar:
  • 85 Answers
The Vga adapter on a ctx ezpro is a video out and will not input from this socket see Vortash2 on you tube for better analaysis
Posted on Dec 07, 2014
    New Friend:
WARNING !!!
13 to 3 - Composite Sync (doesn't work with PC, should be connected to 15)
1 to 2 - R
2 to 5 - G
3 to 9 - B
4 x - (not connected)
5 to 14 - HSYNC gnd
6 to 1 - R gnd
7 to 6 - G gnd
8 to 13 - B gnd
9 x - (not connected)
10 to 11 - VSYNC gnd
11 x - (not connected)
12 x - (not connected)
13 to 15 - HSYNC
14 to 12 - VSYNC
15 x - (not connected)
This is pinout PC VGA
http://pinouts.ru/Video/VGA15_pinout.shtml
This is pinout of CTX EZpro 550
http://old.pinouts.ru/Video/maclIvideo_pinout.shtml
Posted on Mar 13, 2013
    Problem Solver:
  • 25 Answers
Found a pin-out at: http://www.diyaudio.com/forums/diy-projectors/78108-ezpro-550-rgb-cable-pinout.html
1 2
2 5
3 9
4 No conectar
5 14
6 1
7 6
8 13
9 15
10 11
11 no conectar
12 No conectar
13 3
14 12
15 No conectar
You probably need to have a special cable made up.
Posted on Jul 03, 2010
How to connect laptop to vga projector?
you need a cable. it may be the one that usually connects a computer to a monitor = depending what the input is on the projector but it sounds like an ordinary monitor cable as projector is VGA ( the other type has a digital input at one end ;but Im pretty sure thats not it.) If you have another computer set up just borrow the monitor cable and try it. There's already an input for one end in your laptop if its ok buy an extra cable
Mar 18, 2013 | Lenovo S405 14.0inch Laptop
Computer image does not cone out through the projector. the image goes blank immediate i connect it to the computer
try doing a Reset All on the projector, which should be located within the User menu. i'd also check the VGA cable connectors on each ends, make sure there are no bent pins
May 21, 2011 | InFocus LP530V Video Projector 2000 ANSI...
EzPro 585 Multimedia Projector: Hello. I have a problem with my Projetor .. It is ...
check if your projector is capable of the same screen resolution as the laptop.
May 07, 2010 | CTX EzPro 585 Multimedia Projector
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
The vga cable is chopped and the PC end is missing
Is this a standard VGA cable with a plug ato both ends? If yes, they are available where computer equipment is sold. If it is hard wired, you need to take your monitor in for repair.
Mar 21, 2010 | InFocus VGA Cable - 15 pin male-male, 4...
I need to replace the VGA cable on my Sanyo projector, model PLC-XW55. I don't know what to get. It's a male-male cable .
Hi hotpinkvalen
If you have a VGA cable, take it to a computer shop or **** Smith and buy a new one.
Just tell them you want a VGA cable. It costs $6 to $10 depending on the shop.
If you don't have one, and if you don't know how it looks like, goto any desktop computer and have a look at the cable which is connected from the computer to the monitor.
It is a male-male cable both ends of the cable have 15 pins.
Hope this will help you
Best of luck
luciana44
http://www.sanyo.com.au/support/instruction-manuals/plc-xw55-instruction-manual
Oct 01, 2009 | Sanyo PLC XU35 Multimedia Projector
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Color problem
Hi christisfree
Try using a different cable that you connect from your source to the Projector.
A colour change is normally a faulty cable , but if the problem persists after changing the cable , then you might be in for a new Mainboard.
Try the cable and get back to me on this one.
May 08, 2008 | CTX Optoma EzPro 500 Multimedia Projector
Projector problem
it has a faulty rca jack provable. You are lucky you have the computer jack. You can get a little vga to rca adapter i think.
Oct 14, 2007 | CTX Optoma EzPro 610H Multimedia Projector
CTX Optoma EzPro 600 Multimedia Projector Logo
563 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
chinopuma
Level 1 Expert
Arora Singh
Arora Singh
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
