Question about RCA L26W11 26 in. HD-Ready LCD Television
No Power; Red Light not functioning to indicate power is off.
Power is verified to the TV. I have no power on/off indication. no functions at all.
  • 1 more comment
  • sinai Jun 24, 2008
    Are there schmatics which define th L26W11 HDTV. Ans is a question within it's self.
    I need a service repair manual to even know if there is a replacable fuse.
    Need service repair manual.
  • sinai Jun 25, 2008
    User manual is of little value for most trouble shooting or solving internal problems.
    Genius:
  • 1,665 Answers
See chapter 5 page 41 for troublshooting tips
http://www.retrevo.com/support/RCA-D32F750T-TVs-manual/id/402dj499/t/2/
Posted on Jun 24, 2008
  • 1 more comment
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jun 25, 2008
    Use normal PSU fault finding techniques
    Start with , Any power from secondary of chopper transformer, at the diodes)
    usual PSU voltages are 5v,3.3v 12v (the 12v feeds the CCF tubes power generators)
    If yes the psu ok, If no check for 320v across mains smoothing capacitor
    If 320v ok but no output, check for shorts on the output lines (schottly diodes)
    If the PSU is running and there are any leds glowing on the front
    check to see it the flurecent tubes (on each side) are glowing
    they usually have their own supply generators powered by 12v from PSU
  • 44 Answers
Check the power board... then reconnect or press reset..check, this ll work
    Sergeant:
  • 243 Answers
No there are no schematics available online for this model.
You would be most likely best off having it serviced. If you need any further assistance or information let me know.
Thanks,
Nate
  • Nathan Ayers
    Nathan Ayers Jun 24, 2008
    here is the user manual beyond that unless your very knowledgeable in electronics you will want to have this serviced. You can contact RCA directly for the nearest authorized service center.
    Thanks,
    Nate
    Genius:
  • 1,142 Answers
Power supply must be dead
  • Maanita Chadha
    Maanita Chadha Jun 24, 2008
    Please check the fuse if you can or refer to the manual how to replace fuse,,,
    IMP: make sure you unplug the power cable while you check or replace the fuse
    Guru:
  • 1,894 Answers
Since there is no picture indication it can be a problem in ur power board
  • dewan nafees ahmed Jun 24, 2008
    look for damaged components in the power board
    and u can replace them if u have enough experience in electronics.
    thank you
    nope. am afraid.
    getting a schematics is very difficult.
    but i wil try to get one for u surely.
    and we can say that the problem is in the power board. not power source. mostly may be some blown off IC or some other component?
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Flashing red and green power indicator light
Y-Sustain board and its drivers should be checked.
Jul 16, 2012 | Fujitsu Plasmavision 42" TV
Red light mitsubishi wd-52531 what do i do
red light indicates that your tv is getting 5V. supply from power supply. but it does not indicate that microcontroller which is responsible for functioning of tv is working. if you are a technical able person then you can check micro controllers' power supply, its oscillation, its reset voltages, its key matrix, & infrared receiver. so you will be sure where the fault is. or you may call an tv repair expert.
Oct 21, 2011 | Mitsubishi Televison & Video
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
Jul 20, 2011 | Vtech VT 2461 Cordless Phone
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
My sony grand wega kdf e55a20 power light keeps blinking red. what can the problem be?
Red is an indication signal for power connectivity. Recent devices have two power functionalities. Using the remote control would turn off the display of images to power saver mode. A red power light imiting diode display is indication that requiring display of images is achievable by pressing on the display mode button once more. NOTES; Powering on the device may be achieved with the same function buttons as shutting down the entire Device to least communicate with the power supply circuity from outlet sources. The device is in power off mode ready for repower on with the remote control. Requesting the TV to shut down completely would require to press on the TV button firmly until power cuicuit are disbabled completely. Refer to the TV user guide to ascertain fucntionaility modes usual during operations. Goodluck
Jan 08, 2011 | Sony KDF-E55A20 55 in. LCD Television
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
When I power on the tv, the light goes to green and then a few seconds later goes to a red flashing light
When a set is powered up, there are internal checks that are performed. The initial green light indicates that power has been applied. The flashing red light indicates that a problem was found that is preventing the set from functioning properly and it has shutdown to prevent further damaeg. If you can supply the model number, I may be able to provide additional details. Also, check to see if the flashing red light has a pattern. Quite often the pattern will indicate what problem was detected.
Thanks,
Dan
Aug 07, 2009 | Panasonic Televison & Video
KF-WE42 Indicator flashes red.
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | Sony KDF-E42A10 42 in. LCD Television
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
RCA L26W11 26 in. HD-Ready LCD Television Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
