Question about Cyberhome CH-DVD 300 DVD Player
Does not show any pictures
I played some setup buttons, no I can not see any pictures when I played DVD, only sounds,, help, or give me some facctory restore key
    Genius:
  • Cyberhome Master
  • 1,550 Answers
Check in the remote control of the dvd if there be a progresive scan button because you activate by mistake that function,and you need to deactivate .
Posted on Jun 24, 2008
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
My Kawasaki pvs1080 has sound but no picture, no menu, no setup.
There is a small button on top when the screen closes it turns off the display. While the movie is playing press the small button with a small pointing object and see if the display shows something on the screen for a few second and then off (you can sometime see the movie playing but very dim). then there is a problem with the switch not switching the display back to normal. Hope this helps...
Jan 15, 2011 | kawasaki PVS1080
Give sounds, but no picture, how to reset graphics
make sure all your wireing is corectly hooked up
Oct 06, 2009 | Televison & Video
Daewoo DHR-9414/8414 dvd recorder/player won't play zone 4 dvds
Instructions for changing the region:
  • Press the SETUP button
  • Select INIT SETUP
  • Select SYSTEM INFO
  • Using the remote, press 1 1 0 1
  • When the region shows, press 0
  • Press the SETUP button to exit
Aug 29, 2009 | Televison & Video
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Sudden loss of picture, sound comes though ok
It sounds like the exact same problem that my son recently created. The only solution I've determined is to reset the player to it's default settings. Although it took a little while (since the video display was not present), I finally found the right combination of buttons to push on the remote and now the problem is fixed. Insert a disk, then push the following buttons: Stop, Stop, System/Menu, >, >, >, v, v, v, v, v, >, OK
After the above sequence of buttons, the main player screen should reappear on the tv.
Croce23
Jan 04, 2009 | Philips DVD727 DVD Player
Colby dvd -215 i switched vidio options and cannot see it can it be reset?
try this
*********RESET THE DVD PLAYER BACK TO THE DEFAULT SETTING*********
Make sure you do not have a disk in the tray. Using the DVD player remote control:
1) Press the "Setup" button.
2) On the "Right" arrow, press it three times and then press the "Play" button.
3) On the "Down" arrow, press it two times.
4) On the "Right" arrow, press it once, and then press the "Play" button.
5) Press the Setup button.
*The default setting will take affect as soon as you press the setup button (step 5).
Oct 02, 2008 | Televison & Video
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
22 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
