Question about Microsoft Office Outlook 2003 for PC
Laptop higrade laptop, it will start up and run only if any key is continually depressed please can you tell me the problem and a possible solution
  • 63 Answers
Hi Fabbs,
Check the ribbon cable connecting the keyboard to the motherboard.
It could also be the a cracked print on the motherboard and the pressing of the key is flexing the board causing the connection to make.
Hope this helps
Andy
Posted on Jun 25, 2008
2007 Infinite will not start, but all of the lights will come on. what could it be?
There are few possibilities. One is that if you are using a "copy" of a key that requires a "chip". You may need to use the original key that has a chip in it to start the car or place the chip key near the steering column when starting with the copy. Another possibility is that the brake pedal is not being depressed enough when you attempt to start the car. Another possibility is that the car is not fully in park so try starting with brake on and car in neutral gear. If you have manual transmission make sure clutch is fully depressed. Another possibility is that the starter solenoid on the vehicle has failed and replacing the solenoid (sometimes built into the starter) will be needed. Another possibility is that the positive cable running to the starter has too much corrosion on one of the ends. Remove the ends from battery and starter, clean them and replace them.
Jul 02, 2015 | 2007 - 2008 Infiniti G35 Exhaust Muffler...
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
Laptop Keybord is not working properly. If we click on one letter it is showing another letter.
Download and run Ccleaner here:
Run cleaner and registry cleaner. then:
Examine your keyboard for any build-up of dust, dirt, liquids or other particles that could be causing the keys to type the wrong characters. Allow any loose dirt to fall out by inverting and shaking the keyboard lightly.
Plug your keyboard into another computer. If the keyboard works, then the port on your original computer may not be working.
Confirm that your keyboard is set to the English language. Go to your control panel and click on the "Regional and Language Options" icon. If the setting appears to be in a foreign language, change it to English/U.S.
Check if your number lock key is on. If so, depress the key to disengage it.
5
Run a character key test by using the Microsoft Keyboard Diagnostics (MSKEY) program. While in the MSKEY program, hit several keys to make certain that they are the same keys that are identified in the MSKEY window.
Tips & Warnings
Clean your keyboard regularly to keep it free of dust and debris.
To start MSKEY in Windows Vista, select "All Programs>>Accessories>>Run" from the Start menu. Type "mskey" in the box and depress the "OK" button.
Start MSKEY In Windows XP by clicking on "Run" from the Start menu. Type "mskey" in the Open box, then hit "OK." Depress either "PS/2" or "USB" to apply it to your type of keyboard hookup.
Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty.
MSKEY software is only available with Microsoft IntelliType version 1.1 or later.
Good luck. If this helps please consider giving me a good review.
Thank you and good luck
Oct 19, 2010 | Acer Computers & Internet
Car starts but will not continue to run. The battery was dead and it has been suggested that the "key" memory has been lost. The car will start and run for about 3-7 seconds then turn off. It will crank...
Try turning on the ignition (don't start the engine) and depress the accelerator pedal fully 3 or 4 times. It's possible that when the battery failed, the ECU lost it's idling position info from the throttle position sensor.
Nov 08, 2009 | 1998 Chrysler Sebring
1999 Toyata Corolla will not start unless accelerator is depressed. Only continues to run in neutral/park if accelerator is depressed. If shifted to drive engine dies. What are the possible explanations?
check and clean/replace (idle air control) IAC valve. Its probably sticking or motor may be dead, replacing the unit is recommended. This unit controls your engine idle. Hopefully this helps
Aug 16, 2009 | 1999 Toyota Corolla
Hitachi ft 5500 tuner, tuner pre set problem
I bought an FT-5500 in 1983 that I haven't used for ten years but I still have the manual which states the following re pre-sets:
1. Tune into the station to be memorised with the tuning key.
2. When the memory write key is depressed the memory write key indicator lights continuously for about 5 seconds after the FCCS operation with FM reception and immediately with AM reception. One of the 10 preset keys is depressed for memorising the station while the indicator is lit. When the key is depressed the indicator goes off, the memorizing operation is completed and the next time you want ot listen to the station it can be recalled by depressing the corresponding preset key.
If the preset key is depressed during this interval and the FCCS data & broadcassting station are memorised the indicator goes off.
There is more but I think this should be enough to get you going.
Cheers
Graham
Apr 25, 2009 | Electronics - Others
Evesham voyager 8615 gtk
Easiest way is to run eversesthome
click on + by motherboard, click on chipset, click on northbridge at top of right column,
This will id the chipset to google updates.
Apr 14, 2008 | Computers & Internet
Microsoft Office Outlook 2003 for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
