HP OfficeJet t45 All-In-One InkJet Printer Logo
Posted on Jun 24, 2008
Unable to use scanner
My problem is that for some reason I cannot use the scanner. For a long time, I had absolutely no problem using the scanner. Then from one day to the next I could not use it anymore. Everytime I insert a document for scanning, I press the button "Scan" and the screen tells me that the pc is not connected. I cannot understand. I have tried everything in order to resolve the problem. I cannot see that anything has changed recently, and yet this problem persists. I have Windows XP Home Edition. Can anyone please help? Thank you.
  • 1 more comment
  • SirClete Jun 25, 2008
    I have the same problem. All of a sudden it doesn't work when it was doing fine before. I suspect it may be a driver problem but have been unable to fix it.
  • adambrewer Jul 18, 2008
  • Anonymous Feb 05, 2009
    same problem
A
Anonymous
Argg.. same problem
1helpful
Brother printer/scanner MFC-J485DW scanner bar can't find home position
The is a lot of help and videos in the bottom link, but this post appears to fix the issue according to Brother, and the link below that from iFixit gives an alternative solution but way more complicated..
"Unable to Init. AF"
Brother-USA https://help.brother-usa.com > answers > detail > a_id
The message "Unable to Init. AF" will appear on the display for one of the following reasons: i. A foreign object, such as a paper clip or ripped piece of ... Videos
https://www.ifixit.com/Answers/View/332612/Brother+MFC-J825DW+Printer+%22Unable+to+Init+AF%22+Error+Code
https://www.google.com/search?q=Unable+to+Init.+AF
1helpful
2answers
How to pull codes from a 2007 jeep compass without a scanner
iv seen this happens to alot of christler products, the only way iv ever found to get past this is to just use another obd2 scanner
Am unable to use the feeder tray - it keeps saying paper jam. There is no jam -- something seems to be blocking the mobility of the paper. I have it on "office" use and the regular scan works one...
This piece of equipment is very specific, it performs a task that is very detailed and must be accurate. It is for this reason that they are serviced, to prevent damage and malfunction. I strongly recommend taking your scanner to an Epson service specialist. He/She will be able to diagnose the fault and replace the component that is faulty or malfunctioning.
Hope this guidance helps!
All the best!
damnor01
Unable to communicate with HP scanning software
This happened to me a couple times with the HP Series all in one and stand alone scanners. Goto Walmart and buy a USB hub that has a dedicated power supply. For some reason HP is notorious for this problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/hugo_f827544e52871d36
4helpful
4answers
Brother 130c print unable 50
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
Unable to set up scanner at NASCAR event
chances are that you have locked out the freq u are trying to use ... do you know how to operate the unit? if not i can give you some pointers
3helpful
2answers
Unable to install SCAN functions for HP PSC 1610
If you are having issues using your PSC 1610 on the Vista operating system there is actually an easy workaround using "paint" (I'm using "SnagIT").
Check it out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&product=390315&lang=en
For whatever reason you can't use the actual button on the printer/scanner but when you open paint you can scan the doc from your computer.
Hope this helps!
Hewlet Packard Scanner on XP
absolutely not, (MS) it could be for many reasons like incompatible drivers, incompatible OS, mind you if you can double check the right OS platform you have downloaded and the right bit as well, (32 or 64), XP or Vista, can you double check pls, these are some reson why it become too slow
you might want to check on uninstalling this again
Call Drop
MIc is Faulty replacing it will fix the prob
plz do arte the post.
Jul 09, 2008 • Nokia E50
k24674
Grand Canyon Tech
Grand Canyon Tech
