Question about Kenmore 5230 Dehumidifier
Hopper not seated right
I always have to constantly readjust my hopper in order for it to not say "FULL". The hopper is completely empty when this happens or 1/2 way full. Any ideas?
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same problem with my Kenmore dehumidifier. The bucket couldn't be properly seated because the plastic cracked slightly at the site where the bucket normally is held. Because of this, the button that it is supposed to be pushed in to keep the dehumidifier running wasn't pushed in all the way. A friend has a Kenmore with the exact same bucket- tried hers, and it works perfectly.
The problem I have now is that I can't find the bucket for sale.
Posted on Aug 06, 2008
Model40752301
ck to see that bucket is installed all the way back inside cabinet , they sometimes hook the bucket presents switch together with the full switch
Jul 02, 2014 | Kenmore Dehumidifiers
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    My new LG "ld450eal" DeHumidifier
    The switch that says 'Bucket is full' is not adjusted properly.
    It will need to be adjusted, normally a screw driver or pliers,
    so that when its empty the switch is not made or the contacts
    are open.
    If it is in adjustment properly, then the switch is bad and needs
    replacing.
    Before you replace it, check to make sure the wires leading to it
    are not touching, it may be sending a signal meaning 'full' by
    electricaly touching each other at the switch.
    Feb 25, 2011 | LG Dehumidifiers
    The "full light" will not quit blinking.
    you take out the filter screen and vacumn it or run it under warm water. As far as the full light is concerned it probably means the last time you emptied it you didn't seat it back into the unit properly. If you take the tank out and reinstall it the light will probably go off. Sometimes I have to do it a couple of times before it seats properly.
    Apr 24, 2010 | Maytag M7DH65B2A Dehumidifier
    Upon start up the full bucket light goes on even though I have a hose connected
    make sure the hose connection did not work loose. If it did, water will slowly drip and fill up the bucket over time. If you know the bucket is empty, try readjusting it- it may just be cocked a little bit and this will affect the switch.
    Jan 02, 2010 | Kenmore 54701 Dehumidifier
    Empty bucket light is on and dehumidifier will not run
    The float switch for the condensate reservoir (bucket) is malfunctioning.
    It's sending a false signal that the bucket is full.
    Maybe just stuck and needs cleaning or it may have failed.
    May 31, 2009 | Whirlpool AD65USL / AD65USM Dehumidifier
    Leak, non sensing
    I have found this issue to be pretty common on alot of LG dehumidifiers. Try and reseat the bucket so the left and right sides where the bucket meets the dehumidifier are both flush with the dehumidifier. The issue usually is you will notice that the left side sticks out a little farther than the right side. If this is the case that means the bucket s not fully engaged with the sensor and it will keep running even when the bucket is full. If you reseat the bucket and both sides are not even try reseating it again until both sides are flush. Once they are flush let t run and keep an eye on it the first time running it like this. You should notice the full bucket light when the bucket is full now. If you found this solution helpful please rate it.
    Thanks - Tech101
    Jun 09, 2008 | LG DH404E Dehumidifier
    Help
    there is a small tube on the left side where the water comes out. Push a q-tip up there and wiggle it around. When I did it some glop came out and it works again. I have to do this about once a month.
    Apr 24, 2008 | Danby DDR586R Dehumidifier
    NO POWER TO MY DEHUMIDIFIER
    I took my dehumidifier apart and I found why the unit no longer would start.
    First, there is a fuse inside the metal compartment that houses the control circuit board.
    However, the fuse was not blown. Instead I found the relay that controls the compressor,
    (circuit diagram calls it RY-COMP) was not functioning and was left in the open position.
    The relay must switch the compressor on/off based on humidity, full water hopper, and
    maybe other factors like temperature.
    The RY-COMP is a large black plastic component on the circuit board with two
    wires (blue and black) connected at the top. I tested the contacts and they remained
    open when starting up the dehumidifier. Doing a small bit of rewiring so that the blue and black wire
    were connected and also wired to RY-COMP terminal 3, the dehumidifier came back to life.
    However, this is good for proving what broke but without an electronic control to cycle the
    unit on and off and to halt when the water hopper is full it's not a valuable alternative and
    it risks a burnout of the compressor from constant use.
    I think the RY-COMP relay is a solid state relay which could have gone bad from a spike
    in voltage when plugging the unit in or cycling on/off.
    I certainly don't want to buy another unit where the circuitry is not robust enough to survive
    plugging in every couple weeks. I was thinking I could try replacing the relay with a magnet relay which would probably survive spikes much better.
    Mar 03, 2008 | Goldstar DH304 Dehumidifier
    Kenmore 5230 Dehumidifier Logo
    112 people viewed this question
    Top Kenmore Dehumidifiers Experts
    Bill Long
    Mike Squire
    Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
