FixYa.com
Tags:
NEC Cat-5e
Data speed on short cable
By Mini Me - usenet poster
Hi all,
Maybe a "novice" question, but I have a 3 system network using a switch.
I've just been "advised" that 100 Mbps isn't possible over a 2metre Cat 5e
cable (only 10 Mbps). Is this right??
Hard/software (if nec):
1x 10/100Mbps Switch
2x 10m Cat 5e UTP cable (RJ45 terminated)
1x 2m Cat 5e UTP cable (RJ45 terminated)
3x 10/100Mbps NIC's
2x Win98SE
1x Win2kPro
Assigned I.P. addresses
I've changed the 2m cable for a 10m cable and the network seems no quicker.
(I wouldn't expect the network to be too quick as the "workstations" are
200MHz and 233MHz CPU machines!!)
Rgs
Neil
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Well, they were surplus to requirement when the company I used to work for
changed offices and moved 300 miles south...  there were about 20 spare and
the IT admin gave me 5 for myself...
but they can be made up easily...
Think of it this way...  if you put a socket on one wall and a socket on the
other, then put two keystone jacks in them, you basically have to have a
tiny bit of cat5 running between the 2.
I've done this and have a 2 inch piece of cat5 running from one socket to
the other actually, the sheathing is about 1 cm as the separate wires need
to be separated into the jacks.
I don't think there is a minimum restriction...  as long as the data can
flow...  too long however and it will cause problems
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
That has already been mentioned at the start of the thread
Solution #3
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
Are those homebrew or did you purchase???
If you purchased, then could you tell me your supplier please...
B-)
Grumps II...you know you're old when the latest granddaughter has more
hair than you!!!
Solution #4
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
max for utp cat 5 is 100 meters
Solution #5
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
{R} Richard Ashton" <{ @semolina.org> wrote in message
I have a couple of 6 inch CAT5e patch leads.
Very useful for patching routers and hubs together
Solution #6
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
There are no short limits in the spec, but I've seen some speculation that
less than 0.5 metres may cause issues due to not enough twists to prevent
cross-talk.
Could well be bollox - I'm not an electrical engineer (anyone?)
Woz
Solution #7
Not Rated (0)
Grant
Rating: 0%, 0 votes
In the comms room where I used to work, we regularily used 1m Cat5e cables
to interconnect between hubs, switches and patch panels when the chips were
down. Always got full speed (100Mbps) out of them.
G
  Gerard McGovern
  Webmonkey to the stars
    http://www.inkiboo.com
Solution #8
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
On Thu, 18 Oct 2001 23:27:49 +0100, Gerard McGovern
   <c @inkiboo.com> wrote:
But when the chips are down you don't usually get any signal!
(Sorry...)
I have seen some sort of minimum distance on cables, it may have been
for 'crossover' cables only though.  It's not a problem for me, all my
cables are 5m minimum.  (My memory is suggesting 2ft, not 2m, for the
minimum distance, though, and few people wil have cables that short.)
Chris C
Solution #9
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
Ha, like it :-) If it gets that bad, it's time to go home :-)
That rings a bell ... not sure why. I know I've used a 1ft Cat5e cable and
everything still ran fine.
G
  Gerard McGovern
Solution #10
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
There is that but from what i can remember from a year at uni i dont think
this would become a problem uless your transfer huge files. In which chanse
things might lock up and the computers will have to resend data due to
corruption. This might slow down the speed of the actual transfer but i dont
it could be as detremental as to slow it down to 10mbs.
Solution #11
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
To muddy the waters a bit I've got 2 very short leads (6-8 inches) in
my network, made from flat cable with RJ45 plugs at each end & it
appears to have little effect on speeds etc, the network is running
100base full duplex, the leads are between 3 different pieces of
equipment all stacked together on a shelf (CM, Router & Print
Server)....
And why so short, well I was being taken over by the creeping tide of
wires so had to do something...
I'm not recommending, I'm just commenting on what works for me at the
moment (until I find something better)....
B-)
hair than you!!!
Solution #12
Not Rated (0)
LiZzIe
Rating: 0%, 0 votes
i am using a 1.5m cross over cat 5 cable and it works fine at 100. so does
the 15m cable that ive got.
Solution #13
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
That's absolute rubbish.. !!!  you can obtain speeds of 100Mbps on a CAT5
cable up to I believe 100m. I may be wrong here..  but I know for sure that
2m is most definately wrong...
I have a 130ft cable in my house that has no problem transferring at 100mbps
Transfer speed depends on network conditions. If it's set up ok.. it will be
fine.
Solution #14
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
You are spot on for the 100 MB over 100 meters... 10Mb can go upto 300
meters ( not recommended without a hub or a booster)
Beebock
Solution #15
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
In article <9qd7of$1o @plutonium.btinternet.com>,
bestsyst @btinternet.com says...
Better tell it to my client who is running 100MBit over a 50 metre cable
run from the Hub to wallsocket. There is a total of about 90-100metres
running from the hub.
_________________________
Conor Turton
conor.tur @bigfoot.com
ICQ:31909763
Solution #16
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
Um i personally wouldnt wanna take 10 mbps over a 100m as laid down in the
ieee standards.
node length should be a max of 100m including patch cables at either end !!
Solution #17
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
Cheers Beebok..
Incidently, Neil... If you ever do want to go over 100m, you'd need a
network amplifier of sorts..
Can you Help with these Network Cables problems?
Network Cables
difrence of lan wan
lan limit is 40 to 60km then... Answer This...
Repair Service
Find Network Cable Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
