Replacement lenticular screen for vs6041 60 inch mitsh
Need a replacement outscreen for old 60 in tv
  • Anonymous Nov 22, 2008
    need replacement screen for older model 60 inch projection tv Hitachi
We recently cracked our lenticular screen on our 73 in mitsubishi i called the manufacturer and they said they no longer make them. so i looked thru websites to see if i could find some one with a 73 in tv or bigger that they were no longer using or didnt work and i found a guy on www.ksl.com that had an 80 inch tv and we went to go pick up screen cut it to my tv size and it worked!!.
Posted on Mar 02, 2010
Find generic dlp lenticular screen and fresnel screen
I would find out the make of the lens, probably cannon. The Fresnel and Lenticular screens are nothing to do with the size of the picture, the lens does that bit.
Oct 01, 2017 | Televison & Video
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Nov 08, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Replacement lenticular screen Toshiba 50"
i need a lenticular screen for my 50 inch GE rear projection tv. model number is 52gw948 and i also need an outer protective screen as well. you can email me at mweezzee@yahoo.com
Aug 18, 2008 | Toshiba TZ50V51 50" Rear Projection...
Sony Model KP-53s70 (Need a replacement Lenticular/Fresnal screen)
Try here: http://www.tritronicsinc.com/
Or try here, they seem to be able to find hard to find replacement parts, including lenticular screens for Projection TVs:
http://www.tvscreenfinder.com/services
Jul 02, 2008 | Sony KP-53S70 53" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
55 inch projection tv
BUSTY35,
Here is your screen info = protector...PS5501....$155.00
Lenticular = 23430819....NLA Fresnel..23430635...$135.00
...........................................T.
Dec 17, 2007 | Televison & Video
Broken lenticular screen
I have been looking around for one myself. And have actually resorted to calling all of the "Mom&Pop" repair shops in town to see if they have one in the backroom or something. The problem is that most of the finds you get for lenticular on the web have to do with advertising signs and baseball cards. These lenticular sheets are only similar in how they feel to the touch. The lenticular lense on a rear projection tv actually blocks the image behind it and diffuses the light at specific angles. It is also very likely the specific manufacturers used slightly different pitches in the viewing angle, so that you have to replace it with their screen. I will definately continue to watch this posting because I need one as well.
Aug 28, 2007 | Mitsubishi TS-5045 50" Rear Projection...
TOSHIBA 50A60,GOING TO REPLACE LENTICULAR SCREEN
It's pretty simple repair.  Pull bezel, unscrew braces around edges and swap screen out.  Where did you find the lenticular at?  I have the same TV and can't find the part online.
Thanks
Mar 08, 2007 | Toshiba 50A60 50" Rear Projection...
Televison & Video Logo
1,053 people viewed this question
Top Televison & Video Experts
