Question about Coleman Mach 15 Air Conditioner
Compressor tries to turn on but cant.
Coleman mach unit. when the unit is first turned on it works and cools.the compressor turs off and the fan keeps running. when the temperature goes up in the rv, the compressor tries to come back on but it cant. when it is trying to come back on, the fan speed slows down. i replaced the wall thermostat but i still have same problem. could the starting coil be bad.
  • Anonymous Jul 25, 2008
    SAME PROBLEM
    compressor tries to turn on but cant.
    coleman mach unit. when the unit is first turned on it works and cools.the compressor turs off and the fan keeps...
    lynn dean
Try changing out the start up and run capacitors for the compressor.
Posted on Jul 27, 2008
The unit is not cooling. The fan works, the Compressor turns on but after a few seconds shuts off.
The compressor is not always starting...sometimes it tries but does not start...
It could be a capacitor and relay problem... or the compressor could be going bad...
Change the capacitor and start relay first and then see if that gets it going...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 14, 2010 | Coleman Mach III Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
I have a Mach III. Unit blows hot air and bogs down when cooling.
probably (90 %) the compressor's bad, depnding on the repair cost you probbly want to just get another AC unit
Aug 30, 2009 | Coleman Mach III Air Conditioner
Fan works. turn or compressor sounds like it is binding
Sounds like a start capacitor, but you need a meter that measures uf capacitance
Jul 26, 2009 | Coleman Mach III Air Conditioner
Coleman Mach 15 AC just quit. no compressor sound, no fan
If this is a ducted unit, check the thermostat. It has a fuse for protection that may have blown. If the fuse is fine and you have power to the upper units control box, check for 120V incoming power at the control box and also check for incoming 12V on the Yellow and GH wires when tstat is set to high cool.
Hope this helps.
Jun 26, 2009 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
408 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
