Question about GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker Microwave is not getting enough power
When the mircowave is on, the light is dimmer now and the food is not warm as before for the same amount of time. Once in a while, it will turn brigher for a second and then dim again. Is my magnetron going bad?
  • Anonymous Sep 02, 2008
    everything works but not getting hot thanks
  • 958 Answers
The dimming of the light indicates a big amount of current being drawn by the magnetron. can you see sparks inside the oven? looks like the magnetron is shorting out with the ground. what makes it short to ground could be in the wave guide cover...look for some dark spots or accumulation of carbon from old food residue which becomes carbonized due to repeated heating. carbon is a conductive material that shorts the magnetron to ground.
i hope i was able to help
Posted on Jun 25, 2008
GE Spacemaker SL 1800 arching
Get some warm soapy water and clean inside making sure there are no food particals, if no change! the magnetron may be breaking down.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker mircowave not heating- all else works ok
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Feb 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave turns on but does not cook food food does not get hot all other options on oven work fine
you have a bad magnetron . that is the heating source . the part is not cheap. go to sears parts direct and check out the price b4 you have someone check it.
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven Spacemaker Moldel / will not warm food
the most likley problem is the magnetron has gone bad.but there are a couple of thermal sensor in the cabinet that need to be checked. one of those could be bad as well.
Feb 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Jul 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whenever I open the door on my GE Spacemaker XL mircowave the internal fan goes on. This is the fan that goes on when the unit is cooking and not the exhaust fan. It goes off as soon as the door is closed...
That is normal for it to spin for about a second or so becuase of switch changeover but should not remain on constantly when door is open. Have it checked up if it does not happen like the way I described it.
May 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at under parts and accessories. Or call 1-800-626-2002 for GE factory parts
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
