Question about Acer Aspire 5100-5033 Notebook
I gpt this computer froma a friend and i dont have the password what do i do???
  • 22 Answers
Which password dont you have please be specific. is it the startup password or the windows password
Posted on Jun 24, 2008
Tecra A11 can't see all of 3TB drive
Support for Disk Drives Beyond 2.2 TeraBytes (TB) and 4K Advanced Format Sectors
Most legacy systems built before 2011 have a traditional PC BIOS. This type of BIOS uses a Master Boot Record (MBR). The MBR Partitions can define a disk drive capacity up to 2.2TB. Windows operating systems that boot from an MBR are therefore limited to 2.2TB per MBR. A 3TB disk drive in a legacy BIOS and Window system will need a DiscWizard device driver to access the full capacity of a 3TB disk drive. Two partitions will be necessary because of the MBR limitation. The device driver mounts the capacity above 2.2TB with another MBR which looks to the system as a second virtual "physical" device.
GUID Partition Tables (GPT) can define drives larger than 2.2TB. You can use GPT today on any Windows 10/ 8.1/8/7 and Vista system as a non-booting data drive. Windows can only boot a GPT partition on a new type of BIOS called UEFI.
UEFI BIOS desktop systems are new since 2011. Windows 10/8/8.1/7 64-bit and Vista 64-bit operating systems support booting from UEFI and GPT without the need of a non-Microsoft device driver. This is the Windows native solution for booting a 3TB drive to a single partition.
Quick facts about Windows and 3TB drives:
  • Windows 10/8/8.1/7 and Vista support GPT 3TB single partitions
  • Windows 10/8/8.1/7 and Vista can only boot GPT on systems with UEFI BIOS
  • Windows 10/8/8.1/7 and Vista can mount a GPT non-booting data drive
  • Intel RST device drivers before v10.1 do not support 3TB disk drives
  • Windows systems with Legacy BIOS and MBR boot drives are limited to 2.2TB partitions
  • Windows XP does not support GPT
  • Windows XP sees a 3TB drive as 800GB on boot or data drives
  • DiscWizard software can install a device driver which opens the full capacity of a 3TB. You can use it to create a second partition for the capacity above 2.2TB
Sep 27, 2017 | Toshiba Computers & Internet
Windows xp not recognizing my external hard drive
The most likely reason you cannot see your hard drive on your Windows computer but can on your Mac, is that the drive has been formatted for GPT which is only supported on Windows Vista or 7 or above, not on XP.
See the Microsoft article on GPT here and FAQ's on GPT here
Jan 13, 2012 | Western Digital Elements powered by WD 320...
My external hard drive cannot read by my PC at all ,I connect it on Mac os x G4 and i could reformat it nicely,so why on PC.
Assuming that your PC is running Windows XP then this does not support GPT drives which are created when the drives are used in a Mac computer - you would either need to upgrade to using Windows Vista or 7 which do support GPT or else do a low-level format of the drive to completely remove the GPT formatting data by writing zero's into the first 100 sectors of the drive - this will destroy all data on the drive! GPT = GUID Partition Table which allows for up to 128 partitions on a single drive....See http://support.microsoft.com/kb/302873 for detailed information on GPT
Dec 10, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
How tp convert a GPT hard drive to a MBR hard drive? thanks
Boot off your Vista disc and go to the Recovery options. Once inside there access Command Prompt (It is a choice in the Menu) type Diskpart.exe and hit enter. Then type Help you will see many options.
What you want to do is type 'List Disk' select the Disk you wish to convert and so forth. Basically the way to convert from GPT to MBR is in there. You can also clean all data off the disk from inside Diskpart and start over with MBR.
Commands to Convert Disks
convert mbr [noerr]
Use the convert mbr command to set the partitioning style of the current disk to MBR. The disk may be a basic disk or a dynamic disk but the disk must not contain any valid data partitions or volumes.
convert gpt [noerr]
Use the convert gpt command to set the partitioning style of the current disk to GPT. The disk may be a basic or a dynamic disk but it must not contain any valid data partitions or volumes. This command is valid only on Itanium-based computers; it may be unsuccessful on x-86-based computers.
convert dynamic [noerr]
Use the convert dynamic command to change a basic disk into a dynamic disk. The disk may contain valid data partitions.
convert basic [noerr]
Use the convert basic command to change an empty dynamic disk to basic.
http://support.microsoft.com/kb/300415
Mar 11, 2010 | Compaq Presario 1692 Notebook
How to unlock garmin nuvi 660 gps system
Have your friend drive the unit back to the location where he set the PIN and it will automatically unlock once it picks up satellite signals. You can then enter a new PIN into the unit.
Nov 25, 2008 | Garmin StreetPilot c550 GPS Receiver
How to install my printer without the CD installer
dont have installation disk for printer. how can i install on computer
Jul 07, 2008 | Lexmark PhotoJet Z705 InkJet Printer
Password Override
The switch must be reset. Disconnect all the devices cables from the switch, power off the KVM switch, wait 10 seconds, then reconnect the cables to power up the switch.
Sep 30, 2005 | HP Console Switch KVM Switch
Acer Aspire 5100-5033 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
