This may seem like silly answers but...
1. Be sure the power supply is plugged in all the way and that it is not damaged anywhere on the cord all the way up to the TV.
2. Be sure the Sleep Timer is not activated. You wouldn't believe how many times this is actually the case.
If these end up not the case then it is very possible that the safety circuitry in your TV's board could be going out. The TV is shutting it down due to it finding a problem with the circuitry in the TV. Most of the time people choose to replace the TV with a newer model as it is just cheaper to replace it than to have it repaired. This usually only happens in older TV's although I have seen it in TV's as little as 4 years old.
Testimonial: "Thanks 4 your help. I kinda figured I would need to replace the set, considering I had it close to 15 yrs. but I wanted to hold off spending the $$$."
