Question about HP LaserJet 1010 Printer
Printer not detecting
Not able to communicatewith pc
  • Anonymous Jul 08, 2008
    cxfv
  • sandvaldez Sep 04, 2008
    when i go to print something it does not print and only says that the rpint is pending in a box on my screen
    Master:
  • 638 Answers
Try hard reset.
rate the solution as fixya if it helps you.
Posted on Jun 24, 2008
My windows pc is not detecting my lexmark z600 printer
How do you have it connected to you PC Ethernet, USB, Parallel cable? Check your connections. I am assuming it is USB since you have no internet connection at home. Go to your printer settings and see what port it is connected to. If it is a USB make sure it points to that connection in the panel.
Jul 24, 2012 | Lexmark Z600 InkJet Printer
No network
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and access the Internet via the DSL or cable modem.
May 01, 2011 | Computers & Internet
On my HP photosmart how do I find my WPA Passphrase. I have a Nexxt solutions wireless-N broadband router and Cable & Wireless TP Link, routers. I live in Panama, Central America
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers can communicatewith your wireless router.
Apr 15, 2011 | HP Photosmart C6180 All-In-One InkJet...
Add printer driver failed
It will be ideal to reset the PC. so remove your printer from the PC and uninstall the printer driver software. Now reinstall the printer driver software and connect the Printer to be detected which will be detected as a new hardware and installed. Check printer properties to see the ink levels.
Apr 01, 2011 | Konica Minolta PagePro 1400 Laser Printer
My canon pixma MX320 printer won't scan and when it attempts to it says there is no scanner detected
Hi!
Your printer will be detected as scanner if you successfully installed all feature of the drivers from the cd installer.
After installing the driver, the printer should be connected directly to the pc to detect the printer as scanner.
If the printer is on network... connect the usb to the pc that you are using.
Post back if you still have question.
Please rate thanks.
Nov 04, 2010 | Canon PIXMA MX310 All-In-One Printer
My olivetti anyway printer worked fine with my laptop,but will not work with my new pc,just reads no device detected
attach printer your new pc. pc on and printer power on. detect your printer than install driver in your new pc through printer driver cd.
if no detect your printer than right click my computer than properties than hardware than device manager than select any and top option scan for hardware changes, detect your printer and install driver.
Mar 02, 2010 | Office Equipment & Supplies
Cannot install hardware for printer
Is it detect you printer ?
1. If not detect change the USB Cable
2. If not ........... need to check another PC
3. check your pc usb status from control pannel device manager
4. check the virus in you pc
5. if not solved please re-install Windows
6. If not ........... need to repair your printer Main board
Oct 26, 2009 | HP Officejet 4315v All-In-One InkJet...
I have just conected the mpc600f & when the box came up saying new software detected install now i accidentally said do not show again or something along those lines. I have put the disk in but it says...
I suggest you to remove printer connection from the pc Restart the computer and then connect the printer if it detects the printer continue with the steps of Found New Hardware( insert the printer cd into the drive and continue with the installation
if it is not detected then Start--->Control panel ----->printers and Faxes and delete any printer icons in same dailogue box click file menu File-->server properties---> in this dailogue box choose drivers tab select the drivers if any and click on the remove button (remove all the Drivers)
and then restart the printer the printer will be detected
if assume that you know the installation of printer
if not --->control panel--->printer and faxes----> Add printer option
Apr 27, 2009 | Computers & Internet
PRINTER NOT RESPONDING......
this is original driver for your pinter for win xp .but please let me know if u use other operating system like vista or other.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=al-59236-3&lc=en&dlc=en&cc=us&product=3390949&os=228&lang=en
just clik on that then u see file name like 100_215..............exe
then download it then install.
Feb 09, 2009 | HP DeskJet F4280 All In One Printer InkJet
Can't get printer online
1)uninstall driver software.
2)conect the machine to pc and turn it on.
3)find the machine is detected by pc.
4) if detected by pc ,install driver.
5)if it is not detected try another cable,another port.
Dec 22, 2008 | Office Equipment & Supplies
HP LaserJet 1010 Printer Logo
89 people viewed this question
Ben Johnson
