Question about Kitchen Ranges
Does the kenwood ck704 range cooker need hard wiring in or does it work on a 3 pin plug
2 Suggested Answers
  • 4 Answers
SOURCE: DOES THIS COOKER NEED WIRERING
backing number
Posted on Oct 05, 2010
Does it need 6mm hard wired cable or can it be used with standard 13amp plug via ring min
hard wired is the normal way ranges are done unless they are gas .then the electric can be lighter gauge
Apr 23, 2016 | Ovens
How to hard wire to back of cooker
I gather your cooker has a cord and plug? The connections from the cord and plug into the oven would be where you connect the fixed wiring. This must be done by a licensed Electrician ( In Australia)
Sep 30, 2015 | Kitchen Ranges
Magic Chef gas stove range keeps tripping outlet when I plug in the power cord, What can I do??????
get extension lead plug lead from cooker into it do not plug into socket that you usually plug cooker into try another switch on if it still cuts out means fault is with cooker lead and electrics. if you can open plug check wires have not come loose. other than that you must get an electrician!
Oct 25, 2014 | Kitchen Ranges
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
Need a mike wireing diagram for a kenwood trio ts700g transceiver
Hi Mikeymc_2,
With the Connection pins on the plug facing you and the Locating groove in the 6 o'clock position, the pins are numbered from 1 - 4 in an anti clockwise direction.
Pin #1 Microphone
Pin #2 PTT
Pin #3 Chassis Ground
Pin #4 Microphone Ground
Info is from Kenwood. Subject ; Misc Connectors. 26 / 01 / 99. Hope this helps. 73. REX 9Y4PM.
Any problems contact me at rmclea@tstt.net.tt
Feb 27, 2009 | Computers & Internet
I need to wire up the electrics on a gas cooker
the oven should have a flex already fitted, this will need to be plugged in or connected in to a supply ensuring it is correctly fused, i suggest no more than 3 amp.
Oct 05, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Oster rice cooker
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Sep 08, 2008 | Oster 4724 Rice Cooker
Creda concept halogen cooker -2nd hand
bad timer, or the elements are bad. or the breakers are all kicked. check the breakers and the gfci plugs for the kitchen, just as is below.
for the apartment problem, check the breakers in the breaker box, and turn off then back on. if still not working, check the kitchen plugs for a gfci plug (has a tiny push button in the middle, push to reset) being kicked.
Jul 16, 2008 | Creda C361E Electric Kitchen Range
Kitchen cooker
The green wire is the ground,
the white wire is the common,
the red and black wires are the 240 volts (hot) wires)
Nov 15, 2007 | KitchenAid KESC308LSS Electric Kitchen...
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
