SOURCE: craftsman outside keypad
On the back panel of the opener itself is a small pushbutton. Press the button and the indicator near it will light. While the indicator is lit, enter the new 4-digit code on your keypad and it will be set. (You are actually programming the receiver with the new code this way. The wireless keypad doesn't store a code.) The programming light goes off on its own.
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Make sure the battery is good and then locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this button and then walk over to the keypad and key in a 4 digit code and press enter.
SOURCE: Keypad won't work anymore
Lets make sure you are programming it correctly, make sure the battery is new. Press and release the learn button on the motor. Within 30 seconds enter in the 4 digit code followed by the up/down button. The light bulb should flash once. If you can't get it to code in this way you will need to replace the keypad. Thanks BB
