Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
XBox 360 via wireless
Hi I triying to conenct xBox 360 via wireelss using netopia 3347
I enable xBox live games in costum services and set firewall to low but still when I try connect to wireless network after entering WEP is start detecting IP address but its failing
I try power cycle router, xBox
pls help
  • mwojtunik Jun 24, 2008
    I fix It already
  • Herman Rengifo
    Herman Rengifo May 11, 2010
    Post answer so we know :)...
Hi ServiTiendas
To resolve this issue you have to set DHCP client to automatic
Posted on Aug 07, 2008
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
How do I get open nat settings for xbox live gaming? I have enabled the Xbox Live Games in the custom services but my nat setting is still strict!
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jun 19, 2010 | Netopia (3347NWG-VGX) Wireless Router...
How to hookup wireless internet
I am trying to get xbox live working on my xbox 360 console but I need to open some ports and I dont know how , how do I open the ports ? I need to open the port 3074 and I need yo use (UPnP) because I...
Okay so Here is the very simple solution. Go to your router page (192.168.1.254) and select Custom Services. Delete every port opening service you have made. Then Define a Custom Service lets just call it Xbox A and Open ports 80 - 65535 for TCP with the base host port 80 Do tthis twice for both TCP and UDP options. Enable the services on your Xbox (It needs to be Connected and have a static IP adress) It can take about 15 minutes to open all the ports to be patient. Your Xbox also needs to have a static IP adress. Lastly set the routers firewall on low and give it a shot. It worked for me!
Jun 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
Cant connect to xbox live
make sure that your xbox is acctually getting an ip address, by default it should be a 192.168.0.xx number and the gateway should be 192.168.0.254
If however your xbox tells you that its ip address is 168.xx.xx.xx (a private ip address) or if it is simply 0.0.0.0 it would sugest a cabling problem.
However if the network troubleshooter finds no faults and you are still unable to get into xbox live try setting up a PPPoE connection using the username eircom and broadband1.
Alternatively,If you click on Firewall in the Netopia admin page, and set the security level to Low, xbox live would suddenly start to work.
******Also add UDP ports 88 and 3074 if nothing works.On a netopia 3347 you can get this option in the NAT option.U have to enter the port numbers and the service name(xbox).
Hope it works for you.
Apr 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Xbox live
your xbox should work using your netopia but you need to setup some settings. click here on how to.
hope this'll help you
ciao
Sep 28, 2008 | Netopia 2247NWG-VGx Wireless Router...
Xbox live
Hello!
Yes, the netopia router will work with xbox live. you just have to configure some settings on your router.
To configure your router for Xbox Live try the following steps below:
step 1: Open an Internet Explorer page. in address bar type your router ip address, That should take you to the Netopia's settings page
Step 2: On the menu to left click Firewall, set it to Low and Save Changes
Step 3: On the menu to left click Expert Mode, then Yes, enter Expert Mode
Step 4: On the menu to left click Configure, then Advanced, then NAT
Step 5: Where it says Service Name, scroll the list down to Xbox Live Games, click Enable and then Enable again
Step 6: On the menu to left click Configure, then Connection.
Step 7: In main page scroll down to the UPnP and put a check in the box. then Save
It should then restart the Netopia, and when it comes back on in a few seconds your XBOX LIVE should be good to go. If you are still experiencing problems accessing Xbox Live your Netopia may require a firmware upgrade.
May 10, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Still my xbox live update test fails...
Netopia's Modem my also act as a Router protecting your system from internet traffic! You need to check your model to insure what you have. If it is a Router you will have to Contact Netopia in regards to configuring Pin Hole on the Router to open the gaming ports on the Router.
Coach "J"
Have a great 2008!
Jan 07, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
189 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
