Question about Philips Audio Players & Recorders
Radio not working
I have a Philips 15 AS 490 / 00B clock radio 1981 release. Now the RF side of the receiver is not working.
Murphybanton
  • 2004 Answers
SOURCE: radio, clock and cigarette lighter won't work
Have a look at your fuses.
Rate this
Posted on Apr 19, 2009
SOURCE: radio and cigarette lighter do not get power
Is there a fuse for the whippers under the hood or inside the car thats for a 03 corolla
Posted on Apr 20, 2009
  • 6 Answers
SOURCE: Philips cd clock radio
Here is a link to the philps website for your product. The user manual is there. www.p4c.philips.com/
Posted on Dec 29, 2009
mxcaltrz
  • 20 Answers
SOURCE: can't find the fuse box under the driver's side dash on my 2000 suzuki grand vitara. my radio/clock not working and dome light does not come on when the driver's side door is opened.
Its below the Dashboard, on the left side of your knee. You have to use a torch & locate it from under the Dashboard, Its roughly near to the Clutch Pedal.
Here, it looks like this: (The Black one is the Fuse box) ba18901.jpg
Posted on Jan 23, 2010
SOURCE: my daughter has an ONN WA 230 cube radio alarm clo...
press time\alarm button three times for min hand and again for hour
Posted on Jan 05, 2011
Clock has wrong time unable to change
Wrong Time Or Clock Not Set
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsAug 3, 2010 - Features ? > Clock ? > Wrong Time Or Clock Not Set Share on Google+ ... of which receive RF transmissions, you cannot use the Auto Clock Set. ... Press the ? or ? to change the value of the highlighted field and press ... If after reading through the previous troubleshooting steps you still have questions, ...
iPhone/iPad Has Wrong Timezone When Date/Time is Set
Dec 28, 2015 | Audio Players & Recorders
148 gtl receive works fine transmit has no power
Have you checked the 2sc2166 or the 2sc1969? Those are the RF Driver and the RF Final output transistors.
Jan 07, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Need to turn rf gain down inside uniden pc66xl c.b.
The radio should have a RF gain control on the front of it that should drop reception to almost nothing unless sitting side by side in very close quarters.
You could have the receiver detuned but that really makes no sense.
May 16, 2012 | Radio Communications
Transmits but does not receive. cobra29LTD Can it be a active copponent
where is the RF gain? It should be all the way up.
The other thing that can cause no receive. Its a common issue. If you have a mic with a broken wire in cord, if its the wire for receive, then when the key is released the radio will not go into receive mode. The switch in the mic determines weather the radio is in transmit mode or receive mode.
So make sure the RF gain is on max, and try another mic.
Sep 26, 2010 | Cobra 29 LTD CB Radio
Clock keeps working plus 1 hour Lexibook RP200GB set the time but every night it resets to 1 hour ahead can't find user manual please help
Hope this helps I had same irratating problem
1. The RP200 is designed to automatically synchronize its calendar clock once it is brought within a range of 1500km of the Frankfurt DCF77 radio signal. When the RP200 is brought within this range, its auto-control mechanism will override all manual settings.
2. The clock automatically starts scanning the RF 433MHz signal after new batteries are inserted in the main unit. When receiving the RF 433MHz radio signal, the Radio Tower symbol starts to blink. A complete reception generally takes about 10 minutes, depending on the strength of the radio signal.
3. When the reception is complete, the Radio Tower symbol will stop blinking and remain solid
4. For an optimal reception, place the clock away from metal objects and electrical appliances (i.e. television, computer, monitor, etc) to minimize interference.
Notes:
• The unit will receive the RCC signals every day at 2am.
• The RCC signal can also be triggered by holding the key for 2
seconds in time mode.
• When the unit is searching or receiving the RCC signal (which lasts
about 5 minutes), none of the keys is working except the key.
• Press and hold the key for 2 seconds if you wish to stop to the
RCC signal search.
If the RP200 is brought outside the range of the Frankfurt DCF77 radio signal or if the signal is interfered, please set the time and date manually according to the instructions below. If the unit is located within the radio-controlled range, you may want to customize some of the clock settings.
Note: When no key is pressed for more than one minute, the unit returns to time mode (time, date and temperature display
World Time Clock
This function allows you to adjust the clock to a time zone. It is
particularly useful for travelers. Set the clock to the city you are located in, or to a city in the same time zone.
1. In time mode, press [MODE] twice to select the world time clock.
2. Press the key to select the city in which you are located.
3. Press to adjust the summer saving time function.
4. Press and hold [SET] to set the world time as the local time. When the local time is the same as the world time, the icon flashes.
May 15, 2010 | Toys
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
Oregon Scientific RRM326P Snooze button won't work with radio
this is internal speaker control volume defect, please send to repair shop for repair.
Nov 29, 2009 | Audio Players & Recorders
Connect satellite receiver to dvd recordrer
there is really no way around it. Directv and Tivo are releasing a new receiver in a few months. Or you could purchase a HD dvr. Directv's receivers dont send any guide data thru a RF output, only picture and sound. The recorder you have is great for cable.
Jan 06, 2009 | Televison & Video
Jul 04, 2008 | Philips Under-Cabinet Alarm Clock Radio...
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
