Question about JVC AV-27F802 27" TV
On Timer Blinking TV won't come on
During a thunderstorm tv shut off before I could turn it off. TV was plugged into the wall not on a surge protector. Now it won't come on. On timer is red blinking. Is there someting that I could do to reset it or should I consider buying a new tv? I don't want to call a technician for something simple. I do have tools and common sense if I can fix I want to do it.
  • JVC Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
During a thunderstorm my hi sense 55' tv and cable
A power surge could have fried the box and/or the TV.
Sep 13, 2014 | Televison & Video
During a thunderstorm I heard a loud noise and my
A power surge could have fried either or both.
The t v stays on for different amounts of time then shuts off It's a 50". Projection tv
Some TV's have a timer for auto shut off, this menu item may have been set. Check that first! Next, some TV's are negatively effected by slight imperfections in the power from the wall to the TV. I can't tell from your video but if you have too many things plugged into the same circuit, try disconnecting everything else and see if that reduces the incidents. Next, some TV's don't like surge protectors... If your TV flickers a bit before it turns off try disconnecting all other items from the same outlet, remove the surge protector and plug the TV straight into the wall, nothing else... See if that helps. If the last two items seem to help, try investing in a better surge protector.
Jan 21, 2013 | Televison & Video
I have a D52GW12 tv. During a storm a couple days ago there must have been a power surge. I have managed to get the TV's power light to blink but it won't turn on. How do I reset the Tv or fix the...
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
Jun 21, 2011 | Televison & Video
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
TV Lamp light blinking
COULD BE FAN NOT WORKING. TAKE BACK OFF SEE IF TURNING, CLEAN THEM. GO TO SONY.COM,TROUBLSHOOTING, OR SHUT THE TIMER OFF.
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jul 10, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Flashing On Timer
This is usually an indication for a scan failure, and or high voltage failure. Also, the power supply may be damaged.
Depending on the nature of the failure, this type of service can be sort of expensive. I sugget to get an estimate before deciding.
Jerry G.
Jun 11, 2008 | JVC AV-27D302 27" TV
WESTELL MODEM LIGHTS BLINKING
Did you disconnect your dsl connection from the back of the modem? I'm more familiar with cable modems than DSL, but I would imagine they share a commonality: electrical surges coming down the line during lightning storms.
I'm guessing that's what happened to your modem - it probably got surged through the DSL line. Have you called your DSL's support line to see if they have any ideas?
If it's been surged all you can do is replace it. Do check with the DSL company first before you go putting out any major expenses.
Hope this helped!
Feb 19, 2008 | Westell Wirespeed LiteLine 6100...
JVC AV-27F802 27" TV Logo
177 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
