Question about Toshiba Satellite U305-S5097 Notebook
Dvd writer driver missing
My cd drive is working properly in bios and booting time. but i have a problem in windows vista. dvd drive not showing in my computer
Go to Vista tech support. Sometimes if you used a cd/dvd that wasn't compatible with the system, vista creates filters. If you remove the high and low filters, it might help. Vista tech support has a page on how to do this. It worked for me after months of trying everything else.
Posted on Dec 18, 2008
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
HP dx6120 wont boot from cd rom and I want to install windows in a new haerd drive. Is this a bios problem? How do I deal with it.
Possibly a bios problem if the bios is not set to boot from a cd/dvd.
Press Delete key or F2 as soon as you switch on, or whichever key it needs to get in to the bios. Change the boot option to boot from CD/DVD first. Save settings and exit.
Some computers have a one time boot menu which lets you boot from whichever drive you like just for that time. Usually F11, F12, F2.
Jan 28, 2012 | HP Computers & Internet
HP Slimline s3500f, Vista 64-bit. CD/DVD stopped working. I've reloaded the driver several times. Device manager says it is working properly. I have removed upper and lower filters in registry, I have...
A couple of suggestions.
1) Download HP Support Assistant to check for updates on your machine
2) I assume you are using Windows Media Player. Try another free program like VLC. Its handy to have 2 installed so you can toggle between the 2 if one is having problems.
Sep 18, 2017 | HP Pavilion Slimline s3500f Desktop...
Laptop wont boot from cd/dvd drive, hard drive is cleasn, no viru
Hi usavahe.
Booting from CD should be possible.
1) When the laptop first starts to power up, repeatedly press the F12 key. This should bring you to a screen that lets you select the boot device.
2) For the Satellite, it may show icons across the bottom of the screen. You want the one that looks like a CD.
3) It should the start to boot from the Windows CD (if it is indeed a bootable disc) and you will see the message "press any key to boot from cd".
4) Press any key you want on the keyboard and the Windows CD installation process should begin
Hope that helps
Feb 12, 2010 | Toshiba Satellite A105 Notebook
Can i change the operating system from windows vista basic to windows xp?
I would advise you not to do so. Most manufactureres did not release proper drivers for windows XP, as MS didn't encourage them to do so.
I can advise you to install windows 7 instead. I've installed it on all of my computers and I'm more than pleased. You can even run different programs as if the windows was XP... (and no, I don't work for Microsoft...)
Jan 12, 2010 | Acer Aspire 5335-2257 Notebook
How do i uninstall windows vista and making a clean dard drive
You would need a operating sytem cd/dvd (windows xp\windows 7) and a windows COA key. Select your bios to boot from cd\dvd player. Insert the new cd of a different operating system into the drive and restart the computer. It should say press any key to start from cd. Press any key and proceed. You will get to an option to format and install. Format the drive Probably marked C:. This will wipe out the drive and install a fresh copy of whatever OS cd you booted from. Good Luck.
Nov 24, 2009 | Microsoft Windows Vista Ultimate Edition
Windows xp will not install
If you don't see the message on start up "Press any key to boot from cd" Then you need to change the boot order.
Start the PC and hit delete a number of times. This will take you into the bios screen. (Set up screen)
You will have a tab called "Boot Priority" or "Boot order". Make sure that CD/DVD drive has 1st priority. Save & exit & your done. Upon restart if you have a disc in the drive you will get the option to press any key to boot from CD/DVD. By default, most motherboards are set to boot from floppy & then Hard drive so in most cases you will need to enter setup & change the boot order.
Don't forget to rate me.
Oct 19, 2009 | Microsoft Windows XP Home Edition
Missing boot manager
go to system bios (using F10 key on the start "Commanly") then press F9 for restore defaults, and insert the Bootable Vista DVD into the drive, it will solve your prob.. otherwise in bios mode make sure that all the drives (HDD & CD/DVD Rom) are properly installed.
good luck
shafky
Jun 19, 2009 | Tablets & eReaders
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
Toshiba Satellite U305-S5097 Notebook Logo
132 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
