Question about Canon XL2 Mini DV Digital Camcorder
XL2 can't still remove out of cassatte
When opened my XL2 problem with Dv cassate still show in viewfinder '' Eject or Remove DV''..until now i can;t use this camera.
3 Suggested Answers
cpt100
  • 154 Answers
SOURCE: my pc doesn't reckognize the canon xl2 when connected by firewire
Well, I hate that when it happens so we changed test-bed computer to Mac. The software runs as soon as two hardware, pc and XL2 is connected physically. I do not have knowledge on prem pro 1.5. but from technician's point of view, if both machines I/O hardwares are ok rest of the reponsibility depending on the program. This is how I would do it. 1. Restart the computer 2. open only the related program and have it ready for connect. 3. turn on XL2 on VCR mode, test make sure it plays few second. 4. connect the firewire. Hope this works otherwise, I will re-install the program and try. Beyond that point, it's good to consult with a local technician for diagnostic of your XL2 first. -James
Posted on Mar 28, 2009
SOURCE: will not eject mini dv tape
I had the same problem. I cycled through the eject process until it finally gave me back my tape. I had to send it back to have the tape carriage replaced
Posted on May 11, 2010
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
Canon XL2 - eject button issue
Yes, it seems a loose contact on the button's circuitry. The only way to repair this is to take it in for servicing, unless you're willing to live with it :)
Oct 12, 2008 | Canon XL2 Mini DV Digital Camcorder
My canon mini dv camera model no> xl2 is in
If you can't find the manual on Canon's website it's probably not a good idea to go elsewhere. Your best bet is to send it in to Canon and have their techs repair it.
Mar 06, 2011 | Canon Video Cameras
I have a problem in my mini dv (panasonic nv-gs60) it wnt eject please help me
Reduction gear in mechanism is dampered,so it wont drive the cassatte holder,so repelace the reduction gear
Mar 02, 2011 | Panasonic NV-DS65 Mini DV Digital...
Viewfinder and lcd non functioning
I like the XL2. It's a great camera.
The first thing that comes to mind is the connections between the viewfinder and the camera. This is going to involve some electronic troubleshooting. If you're not comfortable with modern electronics then this can usually be repaired fairly inexpensively.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 17, 2010 | Canon XL2 Mini DV Digital Camcorder
Canon xl2 will not take the tape it says remove tape in viewfinder.camera is dry whats going on here
Canon XL series will indicate "remove tape" sign when the head does not read the data when inserted. You probably have clogged head and probably needs cleaning. Depending on the condition of the clogged head, you can try by running head cleaning tape for about 10 sec. If that does not resolve, it shoud be cleaned and adjusted by trained technicians. Good Luck. If need a professional help, go to www.camerarepairjapan.com
Mar 15, 2009 | Canon XL2 Mini DV Digital Camcorder
Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Feb 01, 2008 | Canon ZR85 Mini DV Digital Camcorder
Can't open the dv tape
Solutions * The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. * Once the power source is available, some models require manually unlatching and opening a cover. * When the cover is fully open, the cassette will eject automatically after a few seconds. * If the tape still will not eject, seek assistance from a Service Facility because you need a special tool to remove the tape without causing further damage.
Sep 16, 2007 | Canon MV850i Mini DV Digital Camcorder
VCR into camera
Since it is a Canon XL1S, I don't think that this feature is available (the recording tape to tape) until the XL2 Model. Just in case I am wrong, make sure that you are in VCR mode, and that in the menu options, somewhere there should be an option called Av to DV or something. As for the other part, you have to change what the display shows on the viewfinder. This is also in the menu under display settings, Timecode.
Jul 17, 2007 | Canon GL1 Mini DV Digital Camcorder
Canon XL2 Mini DV Digital Camcorder Logo
90 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
