Question about Bosch SHU3305 Dishwasher
Bosch built in dishwasher won't drain
Unit makes intermittent sounds like something is rattling around inside while washing.doesn't drain completely.have checked the drain hose-not clogged?impellor spins freely
  • Barry Rooks Jun 25, 2008
    I've got the same problem. Tried cleaning all filters, checked drain hose, and impeller. Everything is fine. Seems to be a recurring problem with this dishwasher.
    B. Rooks
  • Anonymous Mar 28, 2014
    expensive bosch d/w will not drain completely.
    Sergeant:
    Champion:
  • 330 Answers
1.
  1. Adjust the level of the washer to mitigate sound.
  2. The water backup is due to the low drain hose mounting position. Check the sink disposal position; the drain hose connection from the dishwasher to the disposal must be placed higher than the present drain hose passing the sink cabinet from your dishwasher.
Posted on Jun 24, 2008
  • Frank Chen Jun 24, 2008
    lets make the position correctly
    Drain hose through the cabinet area must be higher than it connect to the disposal
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 23, 2011 | Dishwashers
Will not drain
Jun 23, 2011 | Thermador DW44Z Built-in Dishwasher
My kitchenaid kudv24 will not drain water out
Jun 21, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
Noise Drain Motor? No Cloged
The Bosch units do have a little noisier drain pump than most other units, so if you don't hear a grinding sound it probably isn't something you would worry about, BUT if it is grinding, then it is a sign that either something got sucked into the pump or that the pump is starting to fail.
Jun 09, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Bosch shx33a issues
sounds like the float is up and unit is in drain mode.if its only humming that is the problem. there is water in. the base.take off side panel and reach in the base with something to dry the bas out. normally this is caused by a leaking hose. if this doesnt fix problem post the question follow up. thanks
Nov 21, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu5304uc/u06 does not drain
sounds like the pump has something in it or the drain line is clogged or kinked some how
Jun 07, 2009 | GE Nautilus 24" Built-in Dishwasher
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Nov 15, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher odor
I have a new Bosch dishwasher which smells up the whole kitchen when the door is opened (between washings). Someone should ban their sales.
May 06, 2007 | Bosch 24 in. SHE43C05UC Stainless Steel...
Bosch SHU3305 Dishwasher Logo
292 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
