Back to:
Barcode Scanners
Generic problem for all Barcode Scanners
Barcode reading Driver
posted by preet_1901 on Jun 24, 2008
i have barcodes on various devices.i want to read them with the help of barcode reader.i also have the list of all devices stored in my database..i want to create one application which reads the barcode of devices and analyzes it..and also it shows that as what is its number and which person is assigned that device for testing or which person is given that device?? kindly help me. Plz provide me the code
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Barcode Scanners problems?
Symbol LS 4000i (ls4000i00000) Handheld
ola gostaria de saber se vcs tem a configura?§ao do...
Wasp WWS800 (633808920074) Handheld
the trigger quit "clicking' and now the scanner does...
NCR 7875 (7875-2050-9090)
Tengo un problema cuando oprimo una tecla que sirve para...
VeriFone Omni 3700 (M097-400-02-US1)...
How do you change the baud rate on an Omni 3750? I...
Symbol LS2208 Handheld
I have a symbol ls2208 scanner for bar codes. I am having...
Loading problems.
Repair Service
Find Barcode Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
